so, what about the 2015 model?
Discussion in 'Gen 3 Prius Main Forum' started by VESPAGUY, May 27, 2014.
  1. VESPAGUY
    VESPAGUY Junior Member
    37
    KCMO
    i've been a fringe viewer to the forums since I purchased my first Pri January 2006... I'm looking for scoop on the 2015 models. please point me in the right direction.
    many thanks!
  2. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    I'm also pretty interested to see what may be upcoming for the 2015 models. I haven't browsed around enough on the forums within the past couple of weeks to necessarily link you to anything. I definitely am going to do some research soon though. Maybe a Google search would suffice!
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
  4. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Toyota's been tight lipped about their upcoming Prius. Electronic and mechanical efficiency progress has been mentioned in some publications. We're all waiting to see what's next!
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    New design ICE that is supposed to be 8 % more thermal efficient + lighter traction motor. Also, body and chassis drops about 250 lbs which would suggest a lot of aluminum body work. All in all, it should equate to about 5 MPG better fuel mileage. Design...who knows
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The 2015 should be exactly like the 2014. The Gen IV Prius will probably be released mid-year as a 2016 model. Just like the Gen III was released mid-2009.
    retired4999 likes this.
  7. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    [ in my best Orson Wells voice impersonation ] "...Toyota will release no new Prius before its time..."
  8. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    I thought the next gen Prius was 2016- not 2015. Is that not right?
  9. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    xpcman above has the timing I am expecting 2016 model maybe we see it in 2015
