2006 prius lots of dash lights on!!!
Discussion in 'Gen 2 Prius Technical Discussion' started by Kellll, May 27, 2014.
  1. Kellll
    Kellll New Member
    My 2006 Prius with 107000 miles has lots of warning lights came on 2 days ago, including red triangle, vsc, check engine light, yellow brake light... Please see attached picture. I can still drive it so I took it to a hybrid auto shop today, since I can't get an appointment with any toyota dealers until next week. I noticed just now that the vent at the right passenger seat is running and making noise, which I never had heard before. I'm currently sitting at the body shop waiting for them to scan the codes, but any suggestions/insights would help. Thank you!!
    I also checked the service history on toyota.com, and look like the previous owner changed the 12v battery in jan 2013.
    52,161
    you may need a replacement hybrid battery.
  3. bisco
    52,161
    how old is the 12 volt?
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Hard to diagnose without the codes. Please post them when you get a chance.
  5. Kellll
    Kellll New Member
    The service history says the previous owner changed the 12 volt battery in jan 2013 so I assumed it's about a year and half old.
    And I'll post the codes as soon as the mechanics have them for me.
    Thanks!!
    usnavystgc likes this.
  6. Kellll
    Kellll New Member
    so they are still working on my car but basically they told me a need a new hybrid battery.
    They haven't shown me the codes yet.
    If I understand correctly, I'm still under warranty of 10 years/100000 miles since I'm in CA. Yes?
  7. Kellll
    Kellll New Member
    Ok the codes are:
    P0A80
    P3021
  8. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    I suspect the previous owner had those codes come up before (hence the 12v battery change before turning it in likely just before the traction battery warranty was up.......I saw the same thing with my car's history too but I had a feeling it needed a traction battery and negotiated accordingly). The noise in the vents is the hybrid battery fan that comes on full bore when it throws the codes you saw.
    Here's your codes:
    P0A80 Replace Hybrid Battery Pack
    P3021 Battery Block 11 becomes weak
    So basically you'll need to either replace the pack or rebuild it yourself as seen here.
    Gen II Prius Individual Battery Module Replacement | PriusChat
    If it´s under warranty obviously you'll want to go that route first (it´s 100k OR 10 yrs so you're likely over)
    #8 MTL_hihy, May 27, 2014
  9. Coolride17
    Coolride17 Junior Member
    55
    With 107,000 miles, sounds like you just missed the warranty, but I hope not for your sake.
  10. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Isn't it 10yr / 150000 miles in a CARB state?
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, 10yr/150,000 mile warranty in a CARB state.
  12. MTL_hihy
    536
    261
    Maritimes, Canada
    I guess now we need to know where the vehicle is registered to see if it's a CARB state or not.
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    He said he's in CA. I assume that means California and not Canada lol.
  14. MTL_hihy
    536
    261
    Maritimes, Canada
    You never know. :ROFLMAO:
    Sounds like this should be covered then.
    #14 MTL_hihy, May 28, 2014
  15. bisco
    52,161
    sounds like you're good to go, brand spankin' new battery from toyota, not too shabby.(y)
  16. Kellll
    Kellll New Member
    So I took my car to a toyota dealer, without even making an appointment , and they confirmed me that I will have a new hybrid battery, for free :)
    Sweet!
    Though they said there's water leak at the engine so they need to change that, together with the belt and coolant. They also strongly recommend to have the battery vent cleaned, which will cost $150.
    So I consider myself really lucky that my warranty hasn't expired yet. I wish I didn't go to the other auto shop yesterday and wasted $125 though. Oh well.
    Thank you everyone!!
  17. SEC
    SEC New Member
    Connecticut
    P0A80 and P0321 error codes.
    2006 Toyota Prius.
    130,086 Miles
    Original HV batt.
    Any HV Batt mechanics (or referrals) in:
    • Fairfield County
    • New Haven County, CT OR
    • Westchester County, NY
