Re-Torque Wheels -- Yay or Nay?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, May 27, 2014.
  1. cyberpriusII
    1,155
    1,762
    Mars Hotel
    I am re-reading John's legendary "Toyota Prius User-Guide Eighth Edition, Eighth Revision for the ICONIC (2004-2009) model."
    And, I had forgotten how much good information that basic document has....but noticed he recommends re-torque of wheels (76 foot-pounds) after 100 miles.
    I googled this and found lots of disagreement....And, I searched this forum and found NO threads (that can't be, I am sure I missed it).
    What's the thought? It's been about 100 miles since I did my disasterous rotation on May 17....
    Actually, not that big of deal...have the afternoon free, guess I will just go out and check.
  2. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    I've never bothered to torque any of the nuts/lugs on any of my cars, but I do check them after 50-100 miles to make sure that they're still tight after having the wheels off. It's more so to check up on myself
  3. Mendel Leisk
    41,295
    I noticed that on a tire shop's bill one time, a caution that I should check (or get checked) the lug nut torques, in about 100 kilometers I think. I've never bothered with it though.
    My main concern is to make dang sure to torque them in the first place: I snug them when the car's off the ground, then gotta remember: torque them first thing, when the car's lowered.
  4. fuzzy1
    10,399
    On one of my previous cars, re-torquing became essential. Not just once, but several times after any tire exchange or rotation. This was discovered when a wheel came loose after a seasonal tire change. While all four where found with somewhat loose lug nuts, that one location always loosened more than the others.
  5. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I check mine to be assured that I can actually get the lugs off when I have to. Some times they have been tightened beyond that point by otherwise well meaning tire guys with air tools.
  6. Patrick Wong
    18,200
    6,500
    That makes very good sense.
    I don't bother to check the torque after 100 miles but then I have no concern about the lug nuts loosening. Since you have good reason to be concerned, then you should check the torque 3x: 2x when you are first installing the tire; then an additional time after 100 miles for good measure.
