not automatic lock when park and out of car
Discussion in 'Gen 3 Prius Technical Discussion' started by hcarddss, May 31, 2014.
  1. hcarddss
    hcarddss Junior Member
    Hello to all.
    I have a Toyota Prius 2012 type 2 and I did install a vip 3200 Plus alarm system. My question is that why is the automatic lock not working? I park the car, get out, and close the door but do not lock the car. After 5 minutes, the automatic lock system is not engage or the alarm system does not arm. Any ideas?
  2. El Dobro
    El Dobro A Member
    7,093
    3,271
    What auto lock?
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I'm not sure if any Toyota has an auto-lock feature when you're not in the car. It should auto-lock when you shift the car into D, or reach a certain speed.
  4. MSA14
    MSA14 Junior Member
    74
    Metro Atlanta, GA
    My 2014 only auto re-lock.
    The car re-locks when I unlock the car via the key fob and never open the door. The car has to be locked already.
    The car does not lock itself when you park it after a drive. You have to manually lock it.
    The re-lock feature is if the unlock button on the key fob is accidentally pressed while in your pocket.
    #4 MSA14, Jun 1, 2014
  5. El Dobro
    El Dobro A Member
    7,093
    3,271
    Both my 2011 and 2012 Gen IIIs do that.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I lock using the button on the armrest. That way I NEVER take my fob out of my pocket.
  7. MSA14
    MSA14 Junior Member
    74
    Metro Atlanta, GA
    Wait.... OP, are you asking about the factory re-lock feature or are you asking about a specific feature that the aftermarket alarm you purchased is supposed to have?
  8. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Just touch the sensor on the outside door handle. I never use the lock button on the armrest.
    Stratman likes this.
  9. ELYKB
    ELYKB Junior Member
    32
    Los Angeles
    2014 Prius Plug-in
  10. fuzzy1
    10,602
    The auto-lock is specific to the alarm system, not the car as supplied from the factory.
  11. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    What Mike said.
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It is very hot and humid outside my car, I prefer doing all my busy work inside
