Understanding Japanese Language in MFD
Discussion in 'Gen 2 Prius Audio and Electronics' started by M Kamran Asif, Jun 4, 2014.
  1. M Kamran Asif
    M Kamran Asif Junior Member
    Hello Friends.. i just for a JDM Prius and the problem is .. i don't have a clue about Japanese language.. i have translate app installed in my android phone but its very difficult to take picture and then understand by selecting each sentence. I looked very hard on every Prius forum to find some kind of information where all possible screenshots are posted along with translations however it seems no one has take this initiative.. or is me looking at the wrong direction ???
    Attached in the picture of my MFD !! Hope anyone can help
    Moreover, can any tell me which mode is this ?
  2. M Kamran Asif
    I thought it was an active forum.. :confused:
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It is, but it's also an English language forum and the number of Japanese speakers/readers are quite low in number.
    Patience is key. What you ask is a common question from people who have purchased ex JDM cars and shipped them to Africa or Asia. You might also want to provide a fuller screen shot of the screen along with what it is you're hoping to establish from the display. Is there a problem with the car? Is it not doing something you'd hoped? A failed/failing 12v is often a problem on this ex JDM cars that may have sat in the docks for months on end.
  4. M Kamran Asif
    Nope.. There is not any problem that i am facing.. I was just hoping if i can get some kind of MFD guidebook..
  5. M Kamran Asif
    Can I get a manual alone for MFD?
  6. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Just done a search on google and from what I can see the text on the bottom left of your photo says "consumption", the text to the right of it say "current consumption" and the text higher up next to the electric motor says "electric motor".
    In fact, there are more screen shots that I could care to read and I'm sure you'll find what you're looking for with a little investigation.
    If I recall from previous responses to similar threads, the JDM MFD doesn't have a change language option. Though I could be wrong.
  7. M Kamran Asif
    Thanks alot friend...
    I am afraid that there is no other way than translating each picture :(
  8. CatsAreGods
    CatsAreGods Junior Member
    46
    I'm pretty sure that if you find English screenshots, you'll be able to understand the Japanese ones.
    Nexus 4 ?
    Data Daedalus likes this.
  9. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    I can read the kana. The upper left just says "Audio" and the center text on the screen just says "Motor" (right next to the little icon that looks like a motor). :)
    But yes, if you find images of all the English screens, you will have it in English as they pretty much correspond.
    You could also have pieced together from the "0.0 km/l" that the text next to it means "(Fuel) Consumption". I presume it's not called "Mileage" since, well.. you and the car use kilometers..
    GrumpyCabbie likes this.
  10. M Kamran Asif
    This screenshot is just to be taken as examples guys.. I was looking like more of a complete manual where every function is laid down and how to use it.
    I have searched literally everything and didn't even get close to what I need :S
  11. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Unfortunately that's the chance one takes buying a JDM grey import. You'll probably find the fm frequency band is different too, usually starting at 77 mhz instead of 88 and often finishing about 93 instead of 108.
    Now whether you can fit an international version is another matter.
  12. M Kamran Asif
    I have got a aftermarket system installed which is serving my need of USB input, iPod, Aux port and radio..
    Still looking for a complete manual of this system.. Here's is model[​IMG][​IMG]
  13. M Kamran Asif
    Plus there is a metal box with some wires is installed under passenger's seat.. Anyone know what's that?
  14. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    No. I have a RHD Prius and there's no box under my passenger seat. Is it a CD/DVD multidisc player? The SatNav dvd unit? do not know.
  15. M Kamran Asif
    I don't know.. Will take out the seat to check it out
  16. M Kamran Asif
    Just searched it.. It's a jbl audio amp
  17. dolj
    dolj Senior Member
    8,502
    4,314
    Wellington, New Zealand
    Yes, that's correct. Regardless of whether your car is a LHD or a RHD, the units under the front seats are the same (if fitted). The unit under the LH front seat is the Sat/Nav unit and DVD reader. The unit under the RH front seat is the JBL stereo amp.
  18. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    M Kamran Asif and GrumpyCabbie like this.
