How Does the "Park" Button work?
Discussion in 'Gen 3 Prius Audio and Electronics' started by rollerguy, Jun 6, 2014.
  1. rollerguy
    rollerguy New Member
    Little Chute, WI
    Today I removed the dashboard pieces around the shift lever, radio, center console and start button in my 2010 Prius. The reason is because I installed a Blu Logic so that I can have hands free talking with my cell phone.
    As I was removing the dashboard pieces, I noticed that the backside of the "Park" button had the wires cut off and they were taped with electrical tape. Essentially, these wires are not connected to anything and must be doing nothing.
    I can park on an incline, press the "Park" button, and it makes the noise we are all accustomed to. The car does not roll; It is indeed in park. My question is, can anyone explain how the "Park" button works when it appears to not have any wired connection?
    52,001
    bluetooth?:confused:
  3. ibmoses
    ibmoses Junior Member
    109
    22
    Pics of wires "cut off" and "taped" please.
  4. rollerguy
    Little Chute, WI
    Sorry, I'm not taking it apart again. The harness was still plugged into the back of the "Park" button, but the wires were cut leaving about 1/2 inch sticking out, and then taped up with electrical tape. As "bisco" replied, "bluetooth:Confused". Obviously it doesn't work via Bluetooth. I'm just curious if anyone out there knows how it does work.
  5. El Dobro
    El Dobro A Member
    7,088
    3,270
    What does it show on the display? When does the P light up?
  6. rollerguy
    Little Chute, WI
    The "Park" button has a small green colored light. The light comes on when the vehicle is placed in Park, and goes out when the vehicle is shifted into drive or reverse.
  7. El Dobro
    El Dobro A Member
    7,088
    3,270
    I wasn't talking about the button, but if it's lit, then it is wired somehow.
  8. El Dobro
    El Dobro A Member
    7,088
    3,270
    Does the "P" on the button light up at night?
  9. rollerguy
    Little Chute, WI
    Yes, at night when you turn on the lights, the "P" on the "Park" button lights up. That's the reason I posted this question. I'm wondering if anyone knows how it lights up, and operates, when there are no wires connected to it?
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    I would imagine there's four wires, two for the actuator and two for the illumination. Without seeing all the wiring, I guess we'll never know.
  11. fuzzy1
    10,482
  12. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I don't know about the Park mechanism engaging when you press the P button (with no wiring), but it will automatically engage Park when you shut the car down, even if it is in D or R.
  13. bisco
    52,001
    i was thinking the same thing, but he said 'when i push the park button', and he mentions the power button in disassembly, so i assume he knows the difference.
  14. bisco
    52,001
    fuzzy 1 makes a good point.^^^
    fuzzy1 likes this.
  15. El Dobro
    El Dobro A Member
    7,088
    3,270
    If only one.
  16. Mendel Leisk
    41,522
    I'm pretty much convinced if I got the gumption to dig down to the innards of the Park button on mine, I wouldn't be seeing cut-off wires. I'm a little incredulous.
  17. El Dobro
    El Dobro A Member
    7,088
    3,270
    Yea, if the button lights up and actuates the parking pawl, then everything's working.
  18. fuzzy1
    10,482
    Only because my first thoughts were wrong, and had to be deleted.
  19. bisco
    52,001
    never stops me from leaving mine, i wouldn't have any posts otherwise.:p
  20. rollerguy
    Little Chute, WI
    Okay, so I am the one who originally asked the question, and it's just killing me how it works. So, I took my dash apart this morning, and now the mystery is solved. I've included pictures.
    Photo 1 shows the top side of the "Park" button.
    Photo 2 shows the underside of the "Park" button, and what appears to be cut off and taped wires (see the "red" circled area). This is what I was referring to when I originally asked the question.
    Photo 3 solves the mystery. Had I taken the time to look at the other side of the underside of the switch, I would have seen that what appears to be cut off wires was really a folded back and taped wire (see the "red" circled area) that goes to the connections to illuminate the lights and operate the parking brake (follow the "red" arrows). If any of you ever take this apart, it's very inconvenient to flip it over due to the cramped space & length of the wires to the other buttons on this piece (EVO, ECO, power & hazard light switch).
    Thanks to all who responded, but now we all know how it operates.
    ftl and Mendel Leisk like this.
