New car , first Toyota, first hybrid - help!
Discussion in 'Gen 3 Prius Main Forum' started by gmaur, Jun 7, 2014.
  1. gmaur
    gmaur Junior Member
    22
    Dearborn, MI
    I've watched the DVD, I've browsed through the manual and I still don't understand this car. After 2 weeks, I have 150 miles on the car and the battery display has never shown it to be more than half charged - mostly under half, like only highlighting/reading 3 bars. I'm averaging 28 mpg. I've driven in power mode and EV mode and neither seems to make a difference to the mpg. I've been on the Hwy with it, but due to construction zones haven't had it up past 60 mph. Most of the miles have been racked up on roads with speed limits of 35/40 mph. I guess what I'm asking, primarily, is should I be concerned about the battery not fully charging? And, is there a break-in period with this car like there was/is with American made autos?
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    You should avoid steady high speeds in the first 600 miles. The battery rarely exceeds 3/4 full and if it does it tries to get back to 3/4 full. On the rare occasions when looks "FULL" you will not be able to do regenerative braking (no where to put it) and will do engine braking instead.
  3. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    New owners tend to fight the system, doing exactly what they shouldn't with the belief that will result in higher MPG. Things like trying to stay in EV as long as possible hurt efficiency. It's counter-intuitive, but that's the way it works.
    The best thing to do is shut off the displays. Just drive it for awhile and see what happens.
    Read through the forum in the meantime too. You'll learn about what to be aware of when you do start watching later.
  4. bisco
    51,786
    that's only 3600 miles/ year?
  5. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    close enough...
  6. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I am not sure how any hybrid can pay off the higher cost unless you drive it. I do nine,times that,much driving and a Prius makes sense. At 3,600 miles a year, I would get a Versa.
  7. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    Short trips are low MPG because it takes the system about 5 minutes to warm up.
    Air conditioning if on tends to bring batt charge down, so in summer one sees less full battery than in winter.
  8. El Dobro
    El Dobro A Member
    7,085
    3,262
    Use the force, Luke.
  9. engerysaver
    engerysaver Real Senior Member
    426
    132
    Tyler, Texas ; USA
  10. gmaur
    gmaur Junior Member
    22
    Dearborn, MI
    Thanks everyone for the input...it helps.
    I'm not driving long distances at the moment (3.8 miles round trip to work), but I expect that to change within the next few months...hence the desire for a fuel efficient, low maintenance, vehicle.
  11. bisco
    51,786
    you're still operating on your first tank, which includes dealer abuse. you'll do much better after you refill and reset your trip meter. let's see, 75 miles/week, you should be refilling around august first.:p all the best!(y)
  12. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Just remember that the warm- up stage gives the poorest fuel economy. 3 miles would just warm the cooling system. If you drive with a very light foot for this stage you will do better. For shorter distances like that a PIP would have been a good choice or a bike. H
  13. gmaur
    gmaur Junior Member
    22
    Dearborn, MI
    Yes, and that means filling the tank about 4x per year. Darn! I was hoping for just 3 tanks per year. :D
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    You will make 3 tanks!! :)
  15. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    You'll never get optimal mileage with a commute that short. The hybrid system won't be warmed up sufficiently to do you any good. Also, try inflating your tires to 40psi front/38psi rear. It's an easy modification -- and can be just as easily undone if you don't like the way the car rides with the higher pressures.
  16. fuzzy1
    10,386
    But note that it is still doing better than a traditional non-hybrid in the same service, which is saddled with the same warm-up issues.
    Trips that short are ideal of plug-in vehicles, and human powered transport.
  17. qdllc
    qdllc Senior Member
    1,375
    400
    I don't know how fast the battery pack looses a charge over time, but I know if you don't drive long, it has little chance to build up a charge. If you drove 40-50 miles a day, you'd definitely see that battery icon fill and discharge as you drive. A lot of my commute home is largely downhill, so I'm near full when I get on the last turn towards home.
  18. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Try force charging, before drive off.
    iPad ?
  19. gmaur
    gmaur Junior Member
    22
    Dearborn, MI
    Exactly. My previous car was getting 18 mpg. I've definitely improved that with just 165 miles on the odometer (I put 15 on yesterday) so I'm not overly concerned about the low mpg, just trying to understand this car and how to max it.
  20. gmaur
    gmaur Junior Member
    22
    Dearborn, MI
    Not sure how to do that, can you explain?
