Hey Nav, shut up please!
Discussion in 'Gen 3 Prius Audio and Electronics' started by IABoy987, Jun 2, 2014.
  1. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Have the Nav package and does a great job of guiding me here and there as I deliver meals on wheels, drive people to their doctor appointments etc. Only problem is when I tell it to take me home and it gets me back onto familiar roads, I can't make it stop talking like I could my Garmin unit. Closest I can get according to the manual is a pause function which is another menu which I don't want to fumble with at 65MPH.
    Anybody else figured out how to stop the nav from "naving"?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Go to Setup -> Voice -> Auto Voice Guidance = Off
  3. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    What I was looking for was way to silence nav as needed not "permanently". My Garmin has a stop button on screen that stops the route.
  4. fuzzy1
    10,603
    There are several different NAV versions, we can't see what you have.
    I have two ways to do this on mine:
    (1) Options -> Stop Guidance;
    (2) [NAV speaker icon at lower left] -> [adjust volume to zero]
  5. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    I did not realize there was more than one nav package. Only thing I can tell you is it came with JBL sound system, otherwise my owners manual only shows one type of screen pictures and does not differentiate.
    Thanks
  6. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Hit the Voice Button on your steering wheel and say, "STOP GUIDANCE."
    KK6PD likes this.
  7. fuzzy1
    10,603
    It will help if you fill in the Model field of your profile. Combined with the year, that should narrow it down.
    My 2012-Three was built after the mid-cycle refresh, when equipment was changed, and lacks JBL. So it is very likely different than yours.
  8. stannc
    stannc Junior Member
    24
    North Carolina
    Interesting, as "getting the NAV to shut up" was one of the features that the "delivery rep" at the dealer insisted on showing me.
    fuzzy1 likes this.
  9. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    Again, using voice commands... you can say "pause guidance" then "resume guidance", also the voice command "lower" will reduce the volume of the guidance lady without stopping guidance.. reverse command is "louder".
    Roland
    KK6PD and BluetoothEdsel like this.
  10. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    I found that I have the XM Navigation package. AND after ALOT of page turning finally found the "secret". Once the route guidance starts (voice announcing turns etc), I can touch the ROUTE bar at lower center of map screen. Another menu pops up and I press the PAUSE bar. To resume I repeat the procedure and voice starts announcing again.
  11. Roland1555
    282
    69
    Vancouver BC
    That is the touch method.... if your windows are closed and the interior of the car is quiet enough, it is doubtless safer to press the voice control button on the steering wheel and issue the same command using voice.... "pause guidance".
    Only use the touch screen if it is safe to take your eyes off the road.
    Roland
  12. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Hi Roland,
    Unfortunately the voice command that you mention does not work. I was in a quiet car with no engine or AC running and windows closed. When I press the voice button on the steering wheel, I hear a phrase that sounds like "please say password". Sounded kind of garbled and mumbled . I read through the whole voice recognition pages in manual and command list but don't see anything for navigation start/stopping, or password. I checked and everything appears enabled in screen menus for voice recognition.
  13. Roland1555
    282
    69
    Vancouver BC
    Very weird error... doesn't sound like the prompt for a password is coming from the car. could be your phone has Bluetooth and is somehow intercepting???
    Use the on screen buttons... exact same thing I was telling you about, just takes your eyes off the road a little longer.
    Roland
  14. Tideland Prius
    16,623
    Given that you have a 2011, you have the "legacy" 7" Denso unit (the same as the 2010 models). I can attest that what Roland1555 suggests works - Pause Guidance.
    The initial blurb she says when you press the VOICE button is: "After the beep, please say a command such as, Go Home, Destination, Phone, Audio or Command List". (Yes, I use the voice button enough times lol). Assuming you haven't changed the settings regarding the VOICE button, you can simply press the VOICE button any time to interrupt her but always wait for the beep before saying "Pause Guidance". I noticed that "Pause" doesn't work as well and tends to result in a different command more than 50% of the time so I tend to be explicit and saying the full command.
    Hopefully the PDF shows up below. Commands are also available in French (Canadian) and Spanish.
    KK6PD likes this.
  15. BluetoothEdsel
    164
    25
    San Diego
    Every time I try to say the voice command "Stop Guidance," it thinks I want to go to Stockton, California. Is it that it really can't understand me over A/C and road noise, or do I need to somehow get into another menu first?
  16. Tideland Prius
    16,623
    I use "Pause Guidance" and that seems to have a better success rate.
  17. Roland1555
    282
    69
    Vancouver BC
    Agree with that, but have to add that when I'm travelling on the highway with the sunroof open.... better to close it before attempting any voice commands.... the little mic up there is just too close to the sound of rushing wind to discern my commands.
    Roland
  18. ursle
    ursle Gas miser
    1,049
    192
    NH
    Err, why if it's guiding you home don't you want it to, or why if you know your way home is it guiding you?
  19. BluetoothEdsel
    164
    25
    San Diego
    OK - I tried saying "Pause Guidance," and it said (paraphrasing), "Sorry, that entry is not in the phonebook." I had the Maps app up and the navigation running. Is there something else I need to do, beyond pushing and releasing the talk button, for it to understand that I'm giving Nav commands?
    Car has no sunroof, windows up, A/C on. Even did this test stopped at a light on a cool evening (not much A/C fan noise) - so it couldn't be much quieter.
    System is Display Audio w/Entune/Nav.
  20. Roland1555
    282
    69
    Vancouver BC
    Likely you have a different command list with Entune than I do with my 2010 JBL DVD based system. If there is not a list of voice commands in your owner's manual, then perhaps they get listed when you press the voice command button on the steering wheel, or another owner here will chime in with a link to the listing for your newer car.
    Roland
