My prius 2010 gen II is giving bad milage. I am getting 16.5 to 17 km/l.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Farjad, Jun 11, 2014.
  1. Farjad
    Farjad New Member
    My prius 2010 II is giving bad mileage. I am getting 16.5 to 17 km/l. when i bought it (6 months ago) it was giving me about 22 to 25 km/l. And now it i not showing me the bar graphs , and green leaf car graph, which it was showing me when i bought it. I checked the battery by vehicle signal check . it gave me around 12.3v in the morning , after leaving off for a full night.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    16.5km/l or 6l/100km is not that bad. If it is hot now and you are running the AC full blast, then that could do it. You are within the realm of possible fuel efficiency for a hot summer or cold winter. But if your driving style has not changed, and your HVAC usage has not changed, then perhaps something else did change like your alignment. Did you hit a pot-hole or curb? How does your tire wear look?
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Potentially two separate problems that only might be connected.
    But the dash not showing information is a separate problem in of itself.
    I'm not so sure this is a good DIY problem to attack. Many, many factors can affect mileage. But your dash not showing certain displays is a very singular and direct symptom of something.
    I'd start with trying to find out why your dash is suddenly not showing certain displays, and perhaps discovery of that problem will lead you to a simultaneous solving of your MPG issue.
    Are you computing gas mileage manually? If your dash is freaking out, and information displays are disappearing, then I don't know if I would trust the vehicles assessment of gas mileage right now.
    Since you say you bought this 2010-6 months ago, I'm assuming you bought it used. How familiar or knowledgeable are you about it's history? Do you know if it was in an accident? Rebuilt or underwent repair? Hopefully this isn't a symptom of a problem acquired during previous ownership.
  4. bisco
    52,091
    what country are you in?
  5. Farjad
    Farjad New Member
    But in past 3 months. . . The outside temp was 20 to 26c.. . And in that weather it gave me around 17kml only without ac.
  6. Mendel Leisk
    41,640
    Just to clarify the fuel consumption units:
    17 km/l = 5.8 liter/100 km = 40.6 mpg (US)
    22 km/l = 4.5 liters/100 km = 52 mpg (US)
  7. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    2010 should be a Gen III. In Japan even the 2009 was a Gen III
  8. M Kamran Asif
    M Kamran Asif Junior Member
    How do you differentiate a Gen II and Gen III ?
    iPad ? HD
  9. Mendel Leisk
    41,640
    The antenna's about 12 to 18 inch on gen two, about 8 inch on gen 3. That's the easiest at-a-glance exterior difference for me.
    Tideland Prius likes this.
  10. Tideland Prius
    16,564
    Gen II
    Gen III
    The headlights are different (there's that little kink at the top vs. the vertically stacked design of the Gen II) and the mirrors are mounted on the doors for the Gen III vs. mounted on the door frame on the Gen II among other differences.
  11. M Kamran Asif
    Then i also own a GenII 2010 prius... It says model 2010 in documents atleast
    iPad ? HD
  12. bisco
    52,091
    interesting. i would do more 12v testing, how old is it? how many miles on the car?
  13. Farjad
    Farjad New Member
    Its about 115000kms. . . .
    Ok leave the mpg problem . . . For me tha bar graph problem is big. . . Try to solve it please.
    #13 Farjad, Jun 16, 2014
  14. uart
    uart Senior Member
    4,220
    1,211
    Australia
    So are all the other functions on that display working, apart from the bar graph with the "green leaf car" display?
  15. Farjad
    Farjad New Member
    Yes all other functions are working fine. It seems like it is turned off , if it has some feature like turning graphon or off, ,
  16. uart
    uart Senior Member
    4,220
    1,211
    Australia
    So please tell us what you do see instead of the graph then. Do you just see a blank screen or is it displaying some other content?
  17. Farjad
    Farjad New Member
    this kind of display i see whenever i drive . This isnt my pic. I see this current graph which changes accordingly to my speed/power. But nothing displayed against the time coordinate of graph i-e 5, 10, 15, 20.
  18. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Wow that's weird, I've never heard of that particular failure before. There have been some cases where the display fails completely due to bad solder joint, but I've never heard of one doing everything else properly except the time graph. Hopefully someone else can help, I've got no idea on that one. (n)
  19. Asim Jahangir
    Asim Jahangir Junior Member
    34
    Its normal for Prius gen II to do 16-17km/l in hot weather. Do you have AC blowing at full when you drive? Has your driving pattern changed?
  20. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Seems like you would do very well to get a mini VCI setup on a laptop PC and open techstream to see if that reveals anything while driving.
