Transaxle maintenance
Discussion in 'Gen 2 Prius Technical Discussion' started by monahj, Jun 12, 2014.
  1. monahj
    monahj Junior Member
    25
    Hyannis, ma
    Hello everybody, I'm about to purchase a used 2009 Prius with 67000 miles. Its a certified car from Toyota. This is will be my second hybrid, but my first Toyota. My other hybrid was a 2003 Honda Insight.
    My question is in regards to the transaxle maintenance. Some of the posts recommend service at 30k and 60k, yet when I spoke to the technician at Toyota he said to only service the transaxle when there is a serious issue with it? Any recommendations??
    I'm a heavy commuter, 850 miles per week. I'm concerned about buying another hybrid, because even with all the scheduled mainenance on my Insight, the tranny let go at 160K.
    Thanks, Jim
  2. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    This is a subject of ongoing discussion on PC. The general consensus is that despite Toyota's position, the transaxle fluid should be changed every 30-60 thousand miles. The procedure is not difficult. If you can change your oil, you can also change your transaxle fluid.
    PC discussion threads
    Transaxle Oil Analysis
    Changing Transaxle oil
    Guides (you can ignore steps about moving/removing the inverter - just drain & fill)
    New England Hybrid Gathering
    Spring maintenance
    Data Daedalus likes this.
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Definitely not 30K miles - a waste of time and money. 60K is on the conservative side also. I'd say 75K is about right.
  4. Epiphany2000
    Epiphany2000 Member
    126
    Also, it pays to call the various Toyota dealers in your area to get the best price on the fluid. I will be changing my fluid soon, and dealers in my area quoted me $9.39 - $11.84 per quart.
    You will need 4 quarts of Genuine Toyota ATF WS (world standard) fluid - Toyota Part #00289-ATFWS
    It is also recommend to replace the crush washers on the drain and fill plugs - Toyota Part #90430-18008 (quantity=2)
  5. Mendel Leisk
    41,863
    The first transaxle fluid change should be sooner than later. Then you can start stretching it. Ignore Toyota, it's your car.
    Epiphany2000 and Mike500 like this.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Mind you, they make more money if you have serious issues with it.
    Change if now and every 60,000 miles, even at the dealer it should be about $110
  7. monahj
    25
    Hyannis, ma
    Thank you for all the replies. Especially, thank you for the part numbers as well as for covering small details like washers.
    I was a little hesitant about buying other hybrid, but with this forum and the amount of quick responses, I'm a lot more confident about purchasing a prius. Thanks again, Jim
  8. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Be sure to open the upper fill plug first before the lower drain plug. If you do it the other way around and have a problem, you are left high and dry.
    monahj likes this.
  9. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I had mine done at 58k in the UK - purely as a precaution on my 2008 Prius T Spirit. I read that it was a lifetime fluid that should last till 120k and only ever needs to be changed once - but I'm equally okay with changing it every 60k or 75k - for peace of mind!
    iPhone ?
  10. Data Daedalus
    1,025
    1,185
    Wembley, London
    Sorry to hear about the tranny failure on your 2003 Insight.
    However, the transaxle on the 2nd generation Prius is over engineered - like the rest of the vehicle. People have reportedly done over 400,000 miles on the same HV traction battery and transaxle.
    Transaxle failures are relatively quite rare - and some of those may have been third party maintenance issues.
    The Gen 2 is an excellent choice. Enjoy!
    iPhone ?
    valde3 likes this.
