2008 prius blower motor instructions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mploesch, May 31, 2011.
  1. mploesch
    mploesch Junior Member
    so cal
    blower motor was intermittent on my 08 prius, now only works when i spin it. does anybody have a pdf or instructions on replacing it myself? the dealer out here is a little pricey and i found a new blower motor on ebay for 50 bucks. thought i might try it first myself, found lots of help in threads on the subject but no visuals which would really help
    thanks in advance for any help
  2. GasserDude
    GasserDude New Member
    Rome, GA
    I searched this same topic here and was amazed at the number of replies that I saw saying that it is a matter of only three screws after the glove box is removed. These people have obviously never changed the blower motor in this era Prius! The first step is to remove the glove box by opening and squeezing in the retainers on both side of the box so that it opens past the normal position. Release the piston on the right side by sliding it off of the pin on the side of the glove box. Then just pull the glove box to you to remove it from the pivot pins on the dash. Next, remove the black panel under the glove box by simply pulling down on it. It has two catches that must release from the top and two pins on the bottom that side into brackets. Once it is off, it is easy to see how to reinstall it. The next step is to remove the transmission control module from the bottom of the blower unit with a 10mm socket. It is held on with two screws and can be left attached to the harness. The next step is the one that no one seems to include. You must remove the condensation pan from below the motor by removing 5 phillips head screws around the periphery. For the two near the back you will need a stubby screwdriver. After removing the screws, remove the pan, being careful no to break off the molded-in drain tube. NOW you are ready to remove the three T25 Torx screws to remove the blower motor. The wire is easier to disconnect from the harness at this point instead of from the motor. Once the motor is out, you can easily release the wires from the motor connection by sliding a flat screwdriver in beside the plug and pushing against it to release the wire. Installation is the reverse of these instructions. I hope this helps someone out there so they have an easier time of it than I did. Took me about an hour (without instructions), and save me nearly $400 over letting the dealership install it. Good luck!
    wlai likes this.
