Question about "V" vs "v" (Upper case vs lower case)
Discussion in 'Prius v Main Forum' started by rsforkner, Jun 14, 2014.
  1. rsforkner
    rsforkner Member
    369
    Boynton Beach, FL, USA
    2014 Prius v wagon
    Spent the past few hours reading various sections of the forums since getting my 2014 Prius V yesterday.
    I see several references that say "Prius v (lower case)".
    Maybe I'm a little slow but what exactly does this mean? As far as I know I have a V-2, one step below the V-3 (navigation). Or do I need to dig deeper into what I have.
    I just traded from a 2008 Hatchback and a lot has changed. It has been a while since I have dug through these forums.
    Thanks,
    Bob
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    It's actually lower case v, for versatile as in multipurpose. Much of the confusion stems from Toyota using Roman numerals like V for 5, I, II, III, and IV previously to denote the trim levels.
    SCH-I535
    The badge on the back of the v looks like PriusV, and the Prius c looks like PriusC. But no one refers to the little Prius as Prius C.
    SCH-I535
  3. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    OK, thanks. Just didn't want anyone jumping on me because I used Prius V instead of Prius v. :)
    Bob
    abundantlyyours likes this.
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Prius c/C and v/V are used somewhat interchangeably here, but the trim levels on the v are Two, Three and Five, not II, III and V.
  5. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    I have 2010 Gen III-IV o_O
    THANKS TOYOTA! ;)
  6. fuzzy1
    10,603
    But the moderators often edit to make corrections on the v/V issue.
  7. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    Thanks all. Sounds a little confusing so unless I have something specific I'll not worry about it. On to the important stuff.
  8. Tideland Prius
    16,621
    Yeah. You have a Prius v while for one model year (2010), the packages (like your Two) were using roman numerals so there was a 2010 Prius II, III, IV and V. Then the v came along and Toyota switched the packaging numbers to letters (Two, Three, Four and Five).
    So in your profile, under "Model", it should be a Two since that's the model you bought - Prius v Two.
  9. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    Late last night I was out on the Toyota site looking for a couple of things and saw that their names are: Prius v Two, Prius v Three, and Prius v Five. So I tried to update my profile here on the forum.
    Under Your Vehicle Year: I only have one Prius v choice: Prius v wagon. Then under Model: I have the Two, Three and Five.
    Thus my profile shows Prius v wagon Two . Go figure.
    Bob
