  1. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    If you don't care about having a functional AM/FM, why not just buy one of the shark fin dummy antennas for $20?
  2. Tommy_Prius
    Tommy_Prius Junior Member
    24
    I was worried about it but after simple tapped into the Homelink mirror, it's working without any problem.
  3. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:What would I gain? The factory antenna mount, minus the antenna, looks close enough to a aftermarket "Shark Fin" antenna, or cover. The black color is close enough on my Winter Gray Metallic Prius. If "time is money", even $20 is a unnecessary expense, while insignificant. As stated in my original post, "consider this another option".
  4. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    IMO, it would look better without something sticking up. Maybe a metric hex screw?
    SCH-I535
  5. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Still a work in progress, but I like the look. I stopped by Lowes this afternoon. Checked out several options. I purchased two black plastic plugs that fit the threaded hole in the base, but the diameter is too big and flat. Need something smaller and tapered. Will respond back with other options.
  6. toyopri808
    toyopri808 Active Member
    226
    116
    Fog light install!
    iPhone ?
  7. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    KennyGS, burstaneurysm and xliderider like this.
  8. xliderider
    8,140
    3,276
    Honolulu, HI
    What foglight is this? I want amber as well, and those have a pretty nice cutoff. (y)
    SCH-I535
  9. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
  10. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    I put 5000k led bulbs in my factory fogs to match my hid's then took my fog lights off and put on DARK yellow lense vynal. Looks CRAZY good! I put the vynal on with them on the car and was almost impossible to do without rinkles so it bothered me until i took them complety off to redo them, not im happy with it! haha
    Vynal
    MetroRestyling High Quality Colored Lens Vinyl Films.
    LED Bulbs
    H11/H8/H9 LED Bulb | H11 CREE LED Fog Light Bulb
    Justdidit, Michael325 and Tweaksalot like this.
  11. xliderider
    8,140
    3,276
    Honolulu, HI
    Thanks, but I want to know what setup toyopri808 has, those are really nice cutoffs on the foglights.
    SCH-I535
  12. Accordlayingkit
    1,616
    1,747
    377
    understood..jus figured id give some other options for ya
  13. burstaneurysm
    469
    144
    Chicago, IL
    Agreed. They look great. I also have yellow vinyl on mine, but they're not nearly as saturated, I suspect he's using yellow bulbs in addition to vinyl?
    Either way, they look awesome and I want.
  14. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    you could also use the yellow fog light housing and pair it with a 3000K HID..... here's my old set up before I replaced my fog lights with projector housing...
  15. xliderider
    8,140
    3,276
    Honolulu, HI
    Unfortunately, those have no discernible cutoff, there is a lot of glare. Unlike your current setup. (y)
  16. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I know... good thing I found those projector housing.... ;)
  17. burstaneurysm
    469
    144
    Chicago, IL
    Which projector housing are you using, bino?
    I used to have 3000K in my xB fog lights, but they didn't glare so damn bad.
  18. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I'm using these...
  19. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
    Hi bino!
    I tried yellow fogs as well. No cutoff, and street signs had a yellow tint to the letters. They seemed to over power the HID bulbs I installed, so I switched back to white halogens & aimed them a bit lower.
    Michael325 likes this.
  20. ibmoses
    ibmoses Junior Member
    109
    22
    Removed the hub caps-found out there are some cool split spoke wheels under there. Ordered some center caps.
    Hardwired a Beltronics RX-65 Radar Detector with Smartcord...
    Installed seat cover(to match Driver Side)on Passenger front seat.
