Pre-filter for traction battery intake?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jejb, Jun 17, 2014.
  1. jejb
    jejb Member
    95
    27
    NW Ark
    2016 Prius v wagon
    I started a thread in the Mileage forum about our new to us Prius, and someone mentioned that we should look into a pre-filter for it since we often have dogs in the car. I tore into the battery intake yesterday, just to check it out. I removed the tube from the squirrel cage fan and had a good look at everything I could see. Clean as a whistle. But I could see where dog hair could get sucked in there, so a pre-filter sounds great.
    Does anyone know about these pre-filters? Are they a roll your own kind of thing, or does someone sell these?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I'd use a screen rather than a filter. A filter might restrict flow.
  3. rsforkner
    rsforkner Member
    369
    Boynton Beach, FL, USA
    2014 Prius v wagon
    I've seen several posts that mention "pre-filters" (or screens) but none that specify exactly what these are. It sounds like an add-on for the traction battery air intake.
    Where do I buy them?
    Dealer, online?
    Where are they installed?
    Do I really need them?
    Thanks for some details,
    Bob
  4. Mendel Leisk
    41,905
    I put a mesh filter behind the air intake grid (in the back seat cushion in our case). It's a coarse weave, you can see right through it. It's a vacuum cleaner motor filter, I happened to have some surplus, just cut it to size and pushed it in, friction-fit.
    rsforkner likes this.
  5. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    Thanks, gives me something to think about...
  6. Indy John
    Indy John Member
    75
    33
    Indianapolis
    Your Toyota dealer's Parts Department can order a snap on "filter" that goes over the back-seat battery air intake. At $30 plus it's something of a rip I think, and it doesn't appear that it would filter very effectively. Never-the-less, I have one on my 2010 hatchback.
  7. Mendel Leisk
    41,905
    ^ Can you post a pic or link? Thanks.
  8. bisco
    52,393
    that's interesting, i had no idea there was an oem. someone mentioned cutting up a/c filters in the past. they are similar to the cabin filter material. i think i would prefer a course foam.
  9. Mendel Leisk
    41,905
    Here's a couple of pics of what I'm using. I've never heard the fan, though maybe I'm not attentive enough. I've checked it a couple of times, has minimum stuff, a bit of dust and a few airborne seeds.
  10. bisco
    52,393
    that looks like good stuff.(y) i have have never heard the fan on any of my pri.
  11. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    Lots of good ideas here. Thanks everyone...
    Bob
  12. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Where is this battery intake? I was out yesterday looking through the back seat storage area and could find nothing.
  13. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    In my 2014 Prius v I found it under the back seat on the right side. I had to open the door and lay down on the floor looking under the seat. Hope that helps. (It's not in the back storage area)
    Good luck, Bob
    Stevevee likes this.
  14. jejb
    jejb Member
    95
    27
    NW Ark
    2016 Prius v wagon
    Same place on our 12 v.
  15. crpriusv
    crpriusv Junior Member
    43
    Delaware
    Agreed. I use a rigid fine mesh plastic screen from a dehumidifier. I cut it to fit over the vent under the right rear seat and taped it in place.
    #15 crpriusv, Aug 22, 2014
  16. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Here's the one for the Gen III hatchback, from another thread:
