Exide 12V mfd Feb 2014 reads 12.49 out of box
Discussion in 'Gen 3 Prius Technical Discussion' started by srivenkat, Jun 17, 2014.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Should I keep it or would it have already sulfated some?
    I haven't broken the caps on the terminals yet while I decide to keep it or not. If I do decide to keep it, I will of course charge it overnight before installing it.
    #1 srivenkat, Jun 17, 2014
    52,335
    it should be fine. give it a trickle charge to top it up before installing. where did you buy it, you may want to bring it back and ask them to charge it.
  3. srivenkat
    596
    93
    IL
    Bought it online from sepbatteries.com . It did come with the vent elbow attached to one side.
  4. Patrick Wong
    18,210
    6,511
    4 months old, 12.5V isn't too bad. I think it would be OK to install it after giving the battery a full charge.
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Nominal voltage for a 12V lead-acid battery IS 12V. After charging they will tend to be closer to 13V and slowly drop as the "surface charge" bleeds away. Depending on the accuracy of your meter 12.49V indicates a very -good- new battery. If it was under 12V I would take it back, but it sounds like it's fine to me.
  6. srivenkat
    596
    93
    IL
    Thanks for the responses/advice.
    I tested with 2 different cheap Digital Multimeters. One showed 12.49 and the other 12.44V. Looking at sulfation risks online, many sources say sulfation starts when the SOC falls below 12.4V (there's a specific gravity measure cited but no easy way for me to check).
    After putting it on the charger overnight, the charger (CTEK MUS 4.3) was in Float stage this morning. The battery measured 13.29V. Will check again tomorrow morning and install.
    For anyone interested, I paid $167.99 including free ground shipping. Did make sure to put in a message for inclusion of the vent elbow, although before ordering I did ask them about the elbow and stock freshness and they said the battery did come with the elbow and further assured me the stock is under a month old. But it took them 5 days to ship it; they told me it took 4 days for them to receive the battery into their warehouse which tells me they likely got it from someplace other than the manufacturer considering it wasn't a fresh battery.
    Another outlet I was considering was atbatt.com but opted for sepbatteries.com since they responded to my web inquiry about the elbow and the freshness of their stock.
    #6 srivenkat, Jun 18, 2014
  7. neez
    neez Member
    194
    37
    Just curious why you didn't go with the Optima yellowtop battery, which is on amazon for $147, free shipping with prime.
  8. srivenkat
    596
    93
    IL
    At 45AH the Exide has more AH (capacity) than the Optima (38 AH) and seems to be rated for faster charging at higher currents (if marketing materials are to be believed, for start-stop technology for non-hybrid vehicles) which I thought would be better suited for the Prius application. The optima is limited to 10 Amps for Battery Charging per the below:
    DS46B24R YELLOWTOP® Prius® Auxiliary Battery 8171-767 | OPTIMABATTERIES
    Even the *new* Toyota TrueStart Prius battery now has 45AH capacity but is still limited to 4.2Amps for charging (according to the label on the battery), hence I didn't go with that one.
    The Prius charging system has been tested by some to charge the 12V at high Amps under certain circumstances and in my layman view the Exide seems to be most capable of handling that.
    #8 srivenkat, Jun 18, 2014
  9. Mendel Leisk
    41,850
    A freshly charged battery will read high. It's called "surface charge". That's about all I know but it's a real phenomena. After a few days installed and driving checking it again will give more realistic reading.
    Also, I thought new batteries typically are not fully charged, not sure. I think you're on the right track charging it with the CTEK prior to install.
  10. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Sorry but that's not true.
    For an old style wet cell the nominal voltage is 12.6.
    For most AGMs, it is 12.8.
    If you charge one up and leave it sit overnight not connected and it only reads 12.0 the next morning, chances are excellent that it is not very healthy.
    That is assuming that your meter is accurate, that is.
  11. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    Nothing to worry about. Everything has a spec range. If it were under 12 is when I would be suspect. If you added up all the 10%and 20% component tolerances in a charging system you would know what I mean.
    As far as meters go. I have a Fluke 87, Fluke 83 V, and a Triplett, 3 or 4 older digital desktop Simpsons as well as a few 3.99 DVMs I picked up at Harbor Freight. I was amazed at how close they all read in current, resistance and voltage.
  12. David Beale
    5,963
    1,989
    Edmonton Alberta
    There is always someone who will disagree on an off-hand comment. I posted a 12V lead-acid battery should measure 12V. Not 13V, not 11V, is what I was implying. Sorry to be so "general".
    So, to be specific, the OP's battery, an "Exide" manufactured unit, according to Exide's spec. sheet, should display the following:
    If "flooded lead acid - deep cycle", at 20% charge - 12.0V, at 50% charge - 12.46V, at 60% charge - 12.52V, at 70% charge - 12.6V, and at 90% charge - 12.7V.
    If AGM, at 20% charge 12.1V, at 50% charge - 12.44V, at 60% charge - 12.5V, at 70% charge - 12.6V, and at 90% charge - 12.9V.
    Reading through the specs an "old type" flooded plate lead acid non-deep cycle battery is the only one that is "not recommended" to allow to reach 20% charge. For that type, you didn't reach 50% charge.
    So your new battery should be fine according to Exide's specifications as you didn't reach "not recommended" areas.
  13. Easy Rider
    982
    210
    N. Central Florida
    And there should be someone to disagree, when the off-hand comment is so off that it gives a false impression. For most uses, 20% charge is considered dead. Appreciate the clarification.
  14. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    If you guys are talking about my disagreement with an off handed remark, all I was saying was basically what others were. Below 12 is a point of concern but, a little more is just sweating the small stuff. Didn't mean to ruffle any feathers but I've just been dealing with both regulated and non regulated power supply systems for about 30 years now and was just pointing out that some things come in at the high or low point of a range but isnt necessarily an issue.
  15. Easy Rider
    982
    210
    N. Central Florida
    He was taking issue with me disagreeing with his incorrect "off hand" remark.I appreciate you chiming in though.
  16. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    I also got mine from Stored Energy Products, mine was mfd in Feb 2013 when I receive it in Feb 2014 it measure 12.9 v right out of the box. I paid $175.
  17. srivenkat
    596
    93
    IL
    Did you actually receive a 1 year old battery and it read 12.9V out of the box? I just wanted to make sure there wasn't a typo.
  18. nedear88
    246
    142
    No typo, I was surprised and kind of pissed off that was 1 year old...but it works well as I am writing this blog. I am sure they charge it before shipping out, the battery post does not have the black plastic cover only the red cover. I also missing the elbow for the vent. I just leave it plugged without vent hose connect.
  19. srivenkat
    596
    93
    IL
    If you contact Stored Energy Products, I am sure they will send an elbow to you.
  20. GregP507
    GregP507 Senior Member
    3,002
    481
    When I sold batteries years ago, the manufacturer rep told us to tell the customer that car batteries had a "70% charge" coming out of the box. I don't know if that was BS or not, but I never heard a complaint from a customer saying that it wasn't true.
