How to remove license plate light assembly?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by slfare, Jun 17, 2014.
  1. slfare
    slfare Member
    64
    136
    Portland, OR
    I've done searches and only found how to replace just the license plate light bulbs, not the entire light assembly inside the hatch. I purchased the Xenon White 24-SMD LED License Plate Light Assembly from iJDMTOY.
    However, getting to the light assembly seems impossible.
    An insight?
    Thank you very much.
  2. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    That is a good purchase! You will have to remove the rear garnish to gain access to the lamp housing.
    Grren4ever likes this.
  3. slfare
    slfare Member
    64
    136
    Portland, OR
    Thank you, RightOnTime. I'm just not sure how to go about removing the rear garnish. Are there any DIY's for removing the rear garnish? It just seems like they could have made it accessible.
    RightOnTime likes this.
  4. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    It's held on by a couple nuts. The rest are clips. You'd have to pry at it slowly, and a plastic pry tool would be handy. Post up pics when you are done!
  5. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Since i am a nice guy and want to help out the Prius Community..................
    1. Take off black panel inside the car. All held on by plastic clips (Designed to be pulled off and on)
    2. To remove the Rear Garnish, there are 4 nuts from the inside that you must remove (8mm)
    Once done, remove the Garnish which is also held on by plastic clips.
    Success!!! :):):):):):):):):):)
    3. Install new license plate lights.
    4. Repeat and rinse :D
  6. slfare
    slfare Member
    64
    136
    Portland, OR
    RightOnTime, I can't thank you enough. Thank you so very much for the detailed instructions and pictures! You are indeed a very nice guy and very awesome. I will try this tomorrow and follow up with pictures!
  7. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    No problem! Good Luck (y)(y)(y)
    This is just a sample of my Build Thread
    Project "Angry Panda"
    slfare likes this.
  8. slfare
    slfare Member
    64
    136
    Portland, OR
    RightOnTime, I couldn't have done it without your guidance. Thank you so very much, again. Pictures below. I am very happy with the results.
    Good riddance, OEM license plate light assembly.
    HeadOfJarg, genetiix and RightOnTime like this.
  9. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    are they W A Y brighter than the stock ones or just a little bit with a different light color?
  10. 2clicker
    2clicker Member
    114
    28
    St. Louis
    what is the purpose of replacing the plate light?
  11. milkman44
    milkman44 Active Member
    591
    386
    Ky
    1. Handling
    2. Horsepower
    3. MPG :ROFLMAO::D
  12. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    So the LEOs can see your license plate from great distances. ;)
    SCH-I535
  13. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    To blind the tailgater behind you...
  14. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    The above comments are hilarious!!!
    Why oh why do we mod our cars?
  15. slfare
    slfare Member
    64
    136
    Portland, OR
    Yes, they are W A Y brighter than OEM.
    It looks nice.
  16. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    Sorry to resurrect an old thread, but I was wondering how this license plate light assembly has held up since you installed?
  17. priusmod
    priusmod Junior Member
    Austin Tx
    Oh, so this is what I need to do. Thanks for the info! I know it's an old post but my 2014 only has 37,000 miles so it's like new to me. The bulb burned out and I followed a thread recommending the new LED lights.
    Burna J likes this.
