PIP Spare Tire Stowage
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Alyn99, Jun 15, 2014.
  1. bisco
    52,269
    and to wrap bodies in.:p
  2. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Bisco, I will try to get some pics later; camera batteries dead, and I can't figure out how to transfer the ones I take with my android phone. In the meanwhile, I think you can use the strap between the two forward tie down rings just behind the rear seat, and snug it down closest to the right side. Or, maybe just run the strap through that right side ring by itself. I'm assuming you have the tire lying flat, right?
    #22 rogerv, Jun 23, 2014
  3. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Hence this is the color that Search and Rescue workers wear, roadside crews wear, Coast Guard helicopters are painted etc.
    No, oh wait, that is bright orange.
    Mike
  4. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
  5. Mike500
    Mike500 Senior Member
    2,593
    767
    Visibility is the reverse of camouflage.
    International orange might be ideal for visibility in an urban environment or at sea, but in a forest, desert, a glacier, blue would be more effective.
  6. bisco
    52,269
    exactly, i'll give that a try, thanks!
  7. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    And to cause confusion:
    Robert Holt likes this.
  8. rogerv
    1,639
    317
    lan,
    Can you tell me about the bumper protector- is it one for another model of Toyota? Thanks.
  9. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    No just for a Gen 3. I think I bought it from eBay but I don't recall who. It was not difficult to find.
    rogerv likes this.
  10. bisco
    52,269
    i cannot get my spare to go below the center hub, do you force it down at all?
  11. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    No just as in the photos, drops in, perhaps 1mm slop. Snug fit with a cloth cover on. The base of the compartment is shaped to take it off centre.
    The tyre is a 125/70-16 Bridgestone, standard space saver spare in the UK.
  12. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    I got one of those from Prius chat shop 3 months ago. If I remember about $40.
  13. aomC
    aomC Member
    65
    28
    2014 Prius Plug-in
    My concern with this is if you're rear-ended... then instead of having that "open" space, that energy will transfer to the tire and the battery pack is right behind it. That area deforms very easily in a rear ender (as the metal plate behind the bumper is designed to do so)..
  14. Okinawa
    Okinawa Senior Member
    1,333
    320
    You made a very smart move. You will feel very comfortable on your trip knowing you don't have that to worry about.
  15. El Dobro
    El Dobro A Member
    7,088
    3,270
  16. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    IMG_20160210_161442.jpg This what I did: Ordered a donut spare (from 2010 Prius) off eBay, used. Then instead of a tire wrap, used and old, but clean sheet to wrap it up. It fits inside the well. I can chose to carry it around all the tile or just longer trips. Easy to remove, hidden by the luggage cover, and reasonably secure. Total cost: $50.
  17. Wolfie52
    143
    124
    No. Carolina
    I got the donut spare (used) off eBay, wrapped it in old, but clean sheet. It fits very snugly and easy to take move about. Total cost: $50. No mess, hidden by the cover and these aren't adding much to the weight of the car.
  18. bisco
    52,269
    well done!(y)
  19. Gerlax
    Gerlax Junior Member
    Maine
    2018 Prius Prime
    Found this cheap tire cover on ebay. Stitching is solid, fabric more than decent. Has a handle! Sits behind passenger seat when taking trips out of the area. Absolutely no regrets. Does the job for $4.99 Many sellers.
    Search Universal Car SUV Tote Spare Tire Tyre Storage Cover Wheel Bag Oxford Cloth
