Does 2012 Tail Lights Fit 2014 Plugin?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PingPong, Jun 23, 2014.
  1. PingPong
    PingPong Junior Member
    2014 Prius Plug-in
    Good afternoon Prius brethren. Just had a minor accident and broke my left rear tail light. Would the 2012 tails fit the 2014 the same? Thanks in advance!
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
  3. RightOnTime
    RightOnTime Senior Member
    755
    1,625
    183
    Kidnapped in OC, CA
  4. PingPong
    2014 Prius Plug-in
    Thanks everyone!!!
  5. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    Sorry to pull up this old thread, but for anyone searching in the future, the 2012-14 PiP taillights are identical, but they are different from the standard Prius taillights of the same era. Standard Prius tails will fit, but they look different and will not match unless you swap both at the same time.
  6. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Yes, the PiP has clear lenses. The regular hatchback has red hockey stick shaped lenses over the brake/running lights.
    SCH-I535
