Burning oil at same rate regardless of oil thickness --- What does it tell us?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AllenZ, Dec 13, 2013.
  1. tivoboy
    tivoboy Junior Member
    SF Bay Area
    I thought you had already bought Auto-RX
    Did you try it yet?
    My oil consumption is down to 1qt per 5,000mi using ARX maintenance doses...
  2. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    You are right. I will try it. But another member commented that maybe using MMO or Auto-RX when burning oil just started will loosen the ring. Looks to me it is too late, the ring is damaged at this point, and leaking will be permanent.
  3. tivoboy
    SF Bay Area
    I still stand by my previous recommendation
    Use ARX at full dose initially and reduce to maintenance doses when consumption drops to acceptable levels
  4. Former Member 68813
    3,524
    981
    US
    Refresh my memory. How bad was your initial consumption and for how long?
  5. AllenZ
    640
    63
    Chicago
    You know, I don't have much confidence on the ARX, because of the "rinse cycle" requirement. From physics and chemistry point of view, there is no sense to have the "rinse cycle" at all. Either it will dissolve the carbon, or it will not.
    But since I already paid $50 for total of 24 oz ARX, I am going to use it. Due to the continue of burning oil, ARX will not last very long, maybe 3000 miles at most.
  6. AllenZ
    640
    63
    Chicago
    It started at 150K miles, at roughly 1500 mi/qt.
    Starting 180K miles, it getting worse, to roughly 750mi/qt, regardless of oil thickness (I once used 20W50 I remember, thick like egg yolk).
    Now it is 214K. roughly 750mi/qt
  7. tivoboy
    SF Bay Area
  8. tivoboy
    SF Bay Area
    At $25 per bottle, I recommend keeping it in there for 10,000 miles by using the group3 synthetic
  9. Former Member 68813
    3,524
    981
    US
    Keep in mind he will go through 13 qts of oil in 10,000 miles. Hardly any additive will be left by the end.
  10. Former Member 68813
    3,524
    981
    US
    Thanks for the link. Here is what I think about your issue. Your oil consumption was not caused by dirty/worn out rings, but rather oil type change. It's not unusual to experience sudden oil consumption when using new oil type that goes away on 2nd or 3rd interval with the new oil. You description sounds exactly like that. The causes for that are unknown, but it's speculated new oil with different chemistry disturbs a balance between rings/cylinderd and oil will be consumed till new equilibrium develops.
  11. tivoboy
    SF Bay Area
    I understand the theory, but don't necessarily agree with it
    If switching to synthetic were the cause in these cases, everyone switching back to Dino with all kinds of treatments should immediately cure them
    In any case, my consumption is still decreasing although I would have been happy with the initial results at 1qt per 3,000mi
    AllenZ would be consuming the 13qts whether he was treating or not
    Actually, by changing Dino at 3,000, he would be wasting 2qts with each of the 3 changes
    AllenZ - Please keep us posted on your methods and results
  12. AllenZ
    640
    63
    Chicago
    After putting AutoRX for only 1K miles, it burned 2qt oil, that's like 500mil/qt, much faster than before at 800m/q
    Is it possible that AutoRX does work, and it resolved SOME carbon on the ring, and actually created a bigger path for oil to crepe in?
    Before that, I've run 10K miles on MMO with no significant changes of the oil burning situation.
    I was planning to replace the engine ($1200 installed for a 65K engine), but now I am interested to know if RX does work, since I still have another bottle (12oz).
    Let me know your thoughts.
    Thanks!
    Allen
    #112 AllenZ, Jun 12, 2014
  13. tivoboy
    SF Bay Area
    What oil are you using?
    Keep it topped off and continue treatment
  14. AllenZ
    640
    63
    Chicago
    I'm using generic regular oil during the treatment, as instructed. Also if using synthetic, cost is too high. Will update.
  15. uart
    uart Senior Member
    4,215
    1,201
    Australia
    It's fine to use regular (non synth) oil, but do stick to a reputable brand. Never use "off brand" gas station of "dollar store" oils. PQIA (The Petroleum Quality Institute of America) has tested some and found them to be very substandard and definitely damaging to an engine.
    SFO and Merkey like this.
  16. AllenZ
    640
    63
    Chicago
    I mostly use the Walmart brand (some Tech?).
  17. uart
    uart Senior Member
    4,215
    1,201
    Australia
    That would be "SuperTech" oil. That's like a Wallmart home brand, but it's an ok oil. That stuff will be "homebranded" from one of the larger legitimate oil distributors.
    Most of the really bad oils that PQIA uncovers are usually small fraudulent oil distributors selling at small discount stores and gas stations. Some of the bad brands they've uncovered are "Super XXX", "Bullseye", "Everclear", "Orbit" and "Maxiguard".
  18. operator
    operator Junior Member
    By the way how do you evaluate amount of oil burned in quarts? I mean I could top it off and see how much is left in quart jug, but does anyone have an idea how much is between MIN and MAX marks? Mine Prius 2009 with 60k burned about 1/3 inch from MAX mark down. Is that much?
    We have moved to Seattle area recently (winter cross-country on Prius was awesome) and here I have to enter the highway uphill on my daily commute, so I guess it is hard on such a small engine. At least every day I'm driving that location I feel the smell of burned oil. I guess it is hard not only for Prius.
    Do high RPM affects oil burning? Or engine wear? Will synthetic oil reduce engine wear on high RPM?
  19. operator
    Addition to the previous message: 1/3 inch in 5k. I guess the smell of buried oil is from other cars running almost full throttle on that part of the road.
  20. uart
    uart Senior Member
    4,215
    1,201
    Australia
    That 1/3" down would only correspond to only about 0.3 quarts, so that's pretty good for 5k miles. That's about what I go through every 2k to 2.5k miles btw (2005 model at 135k miles).
    It will definitely help if you make sure that the engine has a few minutes (minimum) to warm up minimum before doing that.
