Software Versions for PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PhilBlank, Jun 22, 2014.
  1. PhilBlank
    PhilBlank Junior Member
    86
    2014 Prius Plug-in
    Is there a Toyota listing of all of the current software for the PIP models?
    I assume that there is:
    Core Operating System software that controls the car/ICE/EV functions
    Entune Software that connects with your IPhone (or mobile) in its various incarnations
    Navigation Software that contains the latest street maps etc.
    Are there any others that I am missing?
    I presume that there is one of these for;
    PIP Base Model
    PIP Advanced
    PIP Advanced with tech package
    Is there someplace on the Toyota Website where one can find this info?
  2. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Here is a link to Toyota's service site (TIS) that you can buy a two day pass for $15 and view/copy all the service manuals that the dealer service people use. They also use TechStream Software (check ebay) to interface between the car, mechanic, and TIS.
    https://techinfo.toyota.com
    I only track what version of Entune. With the Adv. tech. Pkg. I don't get to choose when to upgrade. When I log on to Entune with my iPad it checks for update and if it's ready the menu will not continue until I upgrade. I'll have to try turning car off to postpone and research the upgrade. I am always wary of upgrades breaking more than they fixed.
    Each Electronic Control Unit (ECU) or computer in the Prius has its own code that is carefully maintained by Toyota. I don't think Toyota gives access to ECU code to guest members. Nor would I chose to play with ECU code that could brick my Prius in a CPU clock cycle.
  3. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    The following is from my 2012 and someone who posted from their 2013
    2012 Plug-in Advanced 12-2013
    EnTune 1.3.232356
    Navigation V6673170
    Bluetooth 21.202
    Gracenote 03451 [2011-01-1]
    Map 21-11-24 [2011-06-1]
    2013 Plug-in Advanced 12-2013
    Entune ?
    Navigation V6673500
    Bluetooth 21.210
    Gracenote 05574 (2013-05-1)
    Map 21-13-27 (2013-06-1)
  4. PhilBlank
    86
    2014 Prius Plug-in
    Here is what it shows on my 2014 PIP Advance with Tech Pkg
    Model - 11TSANNA-AZ02
    NAV V6673600
    BT 21.210
    Grace Note - 05574 (2013-05-01) (what the heck is gracenote)
    I didn't see the MAP date...must be looking in the wrong place...will go back and look again!
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    Just want to point out that the above software versions are for the various components in the nav/audio system. They have nothing to do with any of the engine control units. And there are many of them, all talking to each other.
