possible in NJ?
Discussion in 'Prius c Main Forum' started by njparrothead, Jun 27, 2014.
  1. njparrothead
    njparrothead Junior Member
    North Arlington, NJ
    2014 Prius c
    Hi all, I'm contemplating trading in my 2010 jeep wrangler for a prius c. I live in Bergen County Nj, and drive to Sussex County alot, which is mostly rural. I'm 6'4" and drive 20 to 25000 miles a year? I'm worried about size, country roads, low ground clearance, and winter driving. Anyone experience any issues with any of these? Would i regret it? The mileage is the driving force behind my decision, but i don't want to regret it. Any thoughts will be greatly appreciated.
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    You ask about size but do not tell how many adults you hope to carry. It will be fine for two. If you expect more, get the lift back. County roads will be ideal, the faster you go, the more the liftback makes sense. The c's smaller overhang should help clearance issues. For winter driving, real snow tires.
  3. coyote303
    coyote303 Member
    112
    64
    Colorado
    Only a test drive will determine if you have enough leg room in a c. I am just over 6 feet tall, and the car fits me perfectly. So, your extra height might be an issue.
    Also, if most of your driving is over 55 MPH, a regular Prius might be better. The c can easily handle faster speeds, but a regular Prius gets better mileage at those speeds.
    njparrothead likes this.
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    the C will do everything you listed easily, but the regular prius will do it much better and even easier. im around 6'2" 240 lbs and i find the C just a tad bit cramped, but im still able to do 4 hour drives without stopping.
  5. ejvorb
    ejvorb New Member
    I'm 6'3" and fit fine. The adjustable seat helps, but if anyone sits behind you, it will be tight. I put on about 26000 miles a year and find the c great for my commute (mostly freeway). I've been averaging about 51 mpg going around 70 mph. I haven't done much snow driving yet, but plan to get snow tires for the Michigan winters. I haven't regretted my decision yet. Love my c!
    #5 ejvorb, Jun 28, 2014
  6. wjtracy
    wjtracy Senior Member
    11,360
    3,606
    Northern VA (NoVA)
    Sounds like C is good for tall drivers, and certainly the regular liftback has always had this feature. As far as winter driving Prius should be fine, but keep in mind the highest MPG tires sometimes sacrifice winter driving. So go to TireRack.com to check out ratings in different conditions (wet, snow ice etc).
