FOB not working correctly
Discussion in 'Gen 2 Prius Main Forum' started by exmetrodriver, Jun 30, 2014.
  1. exmetrodriver
    exmetrodriver Member
    124
    Puget sound, Wa.
    My FOB is only unlocking my door. It's not locking doors. Anyone have this happen? Thought it might be the FOB battery. I changed it and still no locking, just unlocking.
    52,274
    did you check each door? could be the motor, or a bad 12 volt.
  3. exmetrodriver
    124
    Puget sound, Wa.
    I checked all the doors and none of them lock when I hit the button, nor can I hear the locks engage. Could it be the FOB? This thing looks weathered.
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Do you have a second fob you can test with to rule out the solenoids and other stuff?
    Could be a bad contact in your primary fob for the locking button.
    SCH-I535
  5. Patrick Wong
    18,210
    6,511
    Are you able to lock the doors by using the lock/unlock button which can be found at the driver's and front passenger's armrests?
    If yes, then the fob is probably at fault. As previously suggested, use a second fob to confirm whether the first fob is at fault.
    If you don't have a second fob, then you are taking a big risk by only having one working fob: if you lose it you will pay big $$$ at your local Toyota dealer to get the car to recognize a new fob, without having a working fob available.
  6. exmetrodriver
    124
    Puget sound, Wa.
    The manual lock switch on the doors work for lock, and unlock. I do only have the one FOB. Getting another is on top of the list. I just got the car 2 days ago. Thanks!
  7. JC91006
    JC91006 Senior Member
    16,813
    8,595
    Does the lock button depress and spring back up? If it stays in the depressed form, it's just stuck and needs to be freed
  8. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    And sometimes this is an early warning sign that the 12 V "aux." battery is getting weak.
    Long shot, probably, if nothing else is acting strange.
  9. exmetrodriver
    124
    Puget sound, Wa.
    I figured it out. Rear hatch was not closed all the way.
    KK6PD likes this.
  10. NinnJinn
    NinnJinn Member
    276
    Indiana
    Hmmm, on my 08, there is a long never ending beep when I try to lock the doors and they are not shut all the way.
