Rear Wiper Blade Insert Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Delta Flyer II, Jun 30, 2014.
  1. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Not sure if there was a post, but I got tired of searching….
    Here are a few easy steps to replace the Rear Wiper Blade Insert on a 2012-2014 Prius.
    If you've noticed the rear wiper blade does not lift very far off the glass…. Pull slightly either side of the retaining clip.
    The wiper will then lift all the way up.
    Take the upper part of the blade and pull back, the wiper blade and arm will then form a T shape. The blade will now lift off the arm easily.
    Once you have the blade you can take it somewhere flat as you will need to bend the blade downward with hands on opposite ends… think of snapping a twig in two over the knee, something like that… just not that aggressive but the two pieces will unsnap and you can then slide the insert out…
    Pull the insert out, pull the metal support rods out and insert the rods into your new insert, repeat the above steps in reverse and you're done.
    Hope this helps anyone who may need to replace their rear wiper insert.
  2. Mendel Leisk
    41,218
    Attached is an excerpt from the Repair Manual. And here's my beef with Toyota:
    Why isn't this in the Owner's Manual !!
    ReDave and pjksr02 like this.
  3. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I purchase mine at Toyota and have them install. Simple. H
  4. spicegirl
    spicegirl Prius shopper
    TN
    This is great, thanks for posting.
    Does anyone have an opinion on whether non-Toyota wiper inserts/refills are okay and work well (not the whole new blade). Or, should I stick with Toyota-brand inserts?
    Thanks!
    spicegirl
  5. Mendel Leisk
    41,218
    I would stick with Toyota, just pick up at dealership parts department too, to avoid any mix-up.
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Where do you get the PDF Owner's Manual?
  7. Mendel Leisk
    41,218
    The Owner's Manual you can download from Toyota techinfo. Just google that expression, and then go to the manuals tab.
