Disappearance of destinations in NAV system?
Discussion in 'Gen 2 Prius Audio and Electronics' started by larkinmj, May 13, 2007.
  1. larkinmj
    larkinmj New Member
    1,996
    This week I was entering a destination in my navigation system. It was one that I had used before, so I was prepared to find it listed in previous destinations. However, I found that all of my old destinations had been deleted. Since then, subsequent new destinations remain in the "previous" category, but all of the older ones are gone (I find it handy to recall a destination from the previous list rather than having to re-enter it). All of the locations designated by "mark" remain. Is there a reason that they would disappear?
  2. qbee42
    3,081
    Any chance you had the Prius in for service? I've had the dealer delete that sort of information by doing an update to the code or something of the sort.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    You can delete previous destinations. Maybe you deleted them all by mistake. DO NOT use the voice command, "Delete all destinations" as I did. I wanted to delete the two destinations I had during a trip but I wiped out all previous destinations, including my Home setting.
  4. larkinmj
    larkinmj New Member
    1,996
    The car was not in for service. Nor did I delete any destinations; I didn't do anything at all. They just disappeared! Except my home setting was still there, and the last destinations that I had in the five presets were still there.
  5. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    Mine does that every so often too.
  6. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    Haven't had that problem yet, but yesterday I decided to remove some from the previous destinations. When I removed an address from my previous destinations it also removed it from my memory destinations if it was the same destination.
  7. qbee42
    3,081
    <div class='quotetop'>QUOTE(Vagabond @ May 13 2007, 07:48 PM) [snapback]441284[/snapback]</div>
    Maybe it's wanderlust, and your Prius wants to go somewhere new and far away. :)
  8. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(qbee42 @ May 14 2007, 06:18 AM) [snapback]441566[/snapback]</div>
    I guess so! I've been itching to make a trip of my own. Maybe I should take my Prius to San Diego or something and let it see some new sites.
  9. Manksgloob
    Manksgloob Member
    243
    I use the "delete all destinations" voice command all the time and it has yet to clear any of my programmed/previous destinations. All it seems to do is delete all/any destinations currently set in your queue for the trip.
    It drives me crazy though -- they use the word "delete" like they do in Star Trek (to remove), rather than how most computer users think of the command (to erase/destroy -- usually permanently).
  10. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Also worth noting is ....if you select "delete personal data" on the sreen setting screen (where you set the color to green/orange), that will get rid of previous points also. Maybe you guys had pushed that.
  11. RichPasco
    RichPasco Richard C. Pasco, Ph.D.
    70
    San Jose CA &amp; Land O Lakes FL
    To delete previous destinations: Press the Menu button, touch the icon My Places, and at the bottom of the next screen touch Delete Previous Points. This is in my 2007 Gen II Prius with the 2012 version of the firmware.
    #11 RichPasco, Jul 4, 2014
