Prius Plug-In Challange
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by El Dobro, Jul 4, 2014.
  1. El Dobro
    El Dobro A Member
    7,093
    3,271
    Just happened to run across this video, this is new to me.
  2. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    It's unfortunate that the contestants only have a month to "learn" how to best drive their PiPs. My own experience has been slow and steady, with emphasis on slow, augmented with the benefit of a lot of tips from this forum. It takes a while to forget how to drive like the owner of a regular gas engine car. But all good PR for Toyota, wherever they are doing this!
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Why wasnt I invited? :d
  4. PhilBlank
    PhilBlank Junior Member
    86
    2014 Prius Plug-in
    Thanks for posting...great video!
  5. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I wonder what the winner will be judged on. Most EV miles alone? What if one team reaches 1000 miles on EV only with no HV miles, but another team gets 10000 miles at say 100mpg? How do you judge the better team? MPGe? I know my numbers are exaggerated, but I don't see how this will be fairly judged.
    CaliforniaBear likes this.
  6. bisco
    52,404
    they don't say in the video?
  7. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Interesting... If all your trips are short there's only one thing to learn. Turn on ECO mode an don't press the accelerator to hard. No gas used in a month is easy.
    However, for longer trips if there are a bunch of novices trying to use P&G on the freeway... :(
  8. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Winners were posted back in November 2013. I believe it was based on highest MPGe and miles driven.
    "Sustainable Morristown, logging an incredible 999 MPGe over 537 miles. The Circle of Care team finished just behind, with an equally impressive 997 MPGe effort over 522 miles. The ARC of Essex County rounded out the Top Three with a 697 MPGe performance over 506 miles. Sustainable Morristown receives a $2,500 contribution from Toyota for their performance, while second and third place contributions of $1,000 and $500 were also awarded."
    PriusC_Commuter and rxlawdude like this.
  9. CaliforniaBear
    1,180
    289
    Northern California
    This would pretty much have to be done with all EV.
    537 mi at 999 mpg is 1.86 gallons. 1.86 gallons times 33.7 kWh/gal is 63.7 kWh. A full charge is about 3 kWh. That's 20.9 full charges. Finally that's 537/20.9 equals 25.7 miles per full charge. That might be done for 500 miles on very flat smooth roads at the optimum speed of 20 mph with no head wind or it might require some downhill. Is that how it was done?
    Any use of gas would make this more incredible as I believe HV only records are in the 100 mpg range for such total distances.
  10. vvillovv
    vvillovv Senior Member
    4,332
    1,516
    NY
    was thinking along the same line.
    "" I wish I could drive where there is a charger whenever I need it. :) ""
    still wondering about the 124 mi ICE issue and how that was avoided :)
    and what they used for gauges, seriously ...
    #10 vvillovv, Jul 5, 2014
  11. vvillovv
    4,332
    1,516
    NY
    opps
    #11 vvillovv, Jul 5, 2014
  12. vvillovv
    4,332
    1,516
    NY
    clicked the wrong edit button twice -delete
  13. retired4999
    2,652
    627
    Eau Claire, Wi.
    I have never been able to even get one 25+ all ev trip let alone 20 of them.
    I have had one trip of 21.3 EV no HV in 28 months of driving.
    vvillovv likes this.
  14. Mendel Leisk
    41,925
    This is one thing that bugs me about the PIP: it's no fun any more ;)
  15. CaliforniaBear
    1,180
    289
    Northern California
    I wouldn't disagree however trips through the mountains can be entertaining.
  16. bisco
    52,404
    i'm having a blast, two years in!(y)
    retired4999 likes this.
