Baking Open Rear Tail Lights?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PingPong, Jul 3, 2014.
  1. PingPong
    PingPong Junior Member
    2014 Prius Plug-in
    I'm pretty well acquainted with baking open headlights on various cars to paint the inner housings but from what I understand, tail lights can be different depending on the vehicle. Some of which can be baked open if it is held with adhesive but there are some that are plastic welded and pretty much gotta be dremeled open. Does anybody know if it would be possible to bake or heat the rear tails open? Any help would be much appreciated. Thanks all!
  2. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Is it really worth that much trouble........I mean REALLY ??
    The end result likely will be a safety hazard and illegal and just a bad ideal in general.
    And pretty much the same thing can be done from the outside........if you insist.
    kmkremer likes this.
  3. peterjmc
    917
    189
    Clarksburg, MD
    Hmm. Wondering if you could bake open the OEM tail lights too. I'm not a big fan of all that chrome paint and would be cool if I could easily black those parts out.
    Dylan Doxey likes this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    Something to consider... unlike the headlight assembly, the tail lights contain some possibly heat sensitive components (LEDs, circuit board) within.
    SCH-I535
  5. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    Hmm.... Really? What's illegal or a safety hazard about opening and closing the taillights? OP didn't even say why they wanted to open them. Maybe there's some debris in the light.. ?
  6. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    The OP is what we call a Car Enthusiast
    "Don't hate the player Hate the Game"
    There are several companies in Japan that specialize in the modifications of Back Taillights.
    Beverly Auto is one of the leaders that can custom Headlights/Taillights
    Unfortunately you got to pay to play!
    Let us know if you decide to explore that concept.
    Good Luck!
  7. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Tail lights are sonically welded. They don't bake off. You'd literally have to cut the lens off with a Dremel and then use a heavy plastic adhesive to reassemble.
    iPhone ?
    Dylan Doxey and RightOnTime like this.
  8. burstaneurysm
    469
    144
    Chicago, IL
  9. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Maybe for some taillights but the Valenti taillights can be easily opened. There's a member here who modify them to retrofit rear fog lights to make them within code for use in Europe and re-sell them as such.
  10. xliderider
    8,140
    3,278
    Honolulu, HI
