What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. scrull
    scrull Junior Member
    36
    24
    Charlotte, North Carolina
    Heated Seats installed. Here are dis-assembly pictures first:
    Theomancer likes this.
  2. scrull
    36
    24
    Next, the install. I put these under my Clazzio seat covers (see above posts). I used the add-a-fuse in the above post to take advantage of the 15AMP heated seat fuse that the Prius C would have used had it come with OEM seat heaters.
  3. scrull
    36
    24
    Next, I popped out the button inserts by the EV/ECO buttons and drilled them out to accomodate the InstallBay 3-way switches:
  4. scrull
    36
    24
    I screwed up drilling one of the buttons and needed to do some JB welding to fix it. I'll have the finished button pictures in the morning when its dry.
  5. scrull
    36
    24
    Buttons installed. They need a little touch-up still, but are fully functional and installed now.
    w2kpugsly likes this.
  6. Nel
    Nel Member
    174
    84
    SF Bay Area
    That's some impressive work with the seat covers and heating. Good job
    Galaxy Nexus ?
  7. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    Did some custom interior wrap, and added Spyder tails. [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Snow, w2kpugsly and Spock like this.
  8. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    I changed my front badge so the background now has a carbon fiber background. I was unable to change the back badge for now... IMG_20140701_092659494_HDR.jpg
  9. yOsHi LiN
    yOsHi LiN Active Member
    215
    138
    los angeles
    2014 Prius c
    I just slam my car lower today, put a tow hook and change bulb to led on the mirror turn signal !!!
    mertechperformance likes this.
  10. -y0-
    -y0- Member
    142
    Pacific NW
    How did you get the side mirror bulbs swapped to LEDs? Isn't it sealed in?
    ztanos likes this.
  11. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    yeah I melt thur the plastic !!!
  12. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Really? Did you take any pictures?
  13. -y0-
    -y0- Member
    142
    Pacific NW
    Did you use a soldering iron?
  14. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    yes I use a soldering iron !!!
  15. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    I fixed two bubble that had came on on my front badge. I de-badged my two back badges and got rid of the ugly blue on the rear badge and let the stock color show. I hope the tape I used stays on.
    IMG_20140703_123409933_HDR.jpg IMG_20140703_123547328_HDR.jpg IMG_20140703_123553385.jpg
    koipond likes this.
  16. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    Today I installed the front bumper "garnish" - it's pretty neat - it has a metallic black finish. I put a blank black plate on it since I live in a no front plate state. I have a Prius C badge on order to stick on to the plate.
    legoadan, ztanos and Danny like this.
  17. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    Where did you get the garnish? Online? It looks really nice.
    Also, nice pic. Your C looks really nice there.
  18. mertechperformance
    532
    126
    Nor-caL
    They're all over ebay but pricey
  19. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    I removed the Passenger Air Bag OFF and Air Bag ON signs from my dash. They're one of the most complained about things in
    the Your complaints/disappointments with your C? | PriusChat thread. I saw someone else do it (I can't find the post) and figured, what the heck.
    So I followed this video to remove the panel, it was super easy.
    Then I blacked out the section I wanted with permanent marker. The permanent marker wasn't doing well. Use your sisters nail polish, the coat is thick and it blocks all the light.
    I used my camping flashlight to make sure no light could come through and installed it back in my car after waiting forever for it to dry.
    Finished product is great. it makes a total difference and makes me less OCD.
    #159 legoadan, Jul 4, 2014
    koipond likes this.
  20. orenji
    orenji Senior Member
    5,887
    3,490
    And this is why states do inspections on cars! How will you know if the airbag has a malfunction?
    Black electrical tape would have been a simpler and easier method of blocking out the icons and which can be removed when needed.
