Found a 2005 with only 67K - should I be concerned?
Discussion in 'Gen 2 Prius Main Forum' started by 3MCS1DJ, Jul 8, 2014.
  1. 3MCS1DJ
    3MCS1DJ New Member
    Richmond, VA
    I found a 2005 with only 67K on it. I imagine that it has sat a while from time to time. I am new to the world of Prius - should I be concerned? Is it bad for the hybrid battery to sit without a charge for long periods of time?
    The car looks super clean and well cared for.
    Or have I found a great low mileage car I should jump on?
    Thanks in advance.
  2. 3MCS1DJ
    3MCS1DJ New Member
    Richmond, VA
    Also, the seller says it has Bluetooth. My research says that Bluetooth was not available in 2004 and 2005 - but it appears to have the controls for Bluetooth on the steering wheel. Not 100% sure though.
    Thoughts?
  3. Epiphany2000
    Epiphany2000 Member
    126
    40
    San Francisco Bay Area, CA
    I bought a 2005 with 66k last December, and it has been working fine for me. There is some evidence that battery desegregation is caused more by age than mileage. Thus, some people recommend buying a newer model with higher mileage versus and older model with low mileage. However, there are many other factors that affect the life of the HV battery as well. Heat is definitely a culprit in this regard, so a car that has been parked in a garage and/or lived in a temperate environment might be desirable.
    Are the service records available? If there is nothing obviously wrong with the car & you are interested in buying it, I'd have it inspected at a Toyota dealer (not the one you are buying it from, if indeed this car is from a Toyota dealer).
    xpcman likes this.
  4. 3MCS1DJ
    3MCS1DJ New Member
    Richmond, VA
    Thanks, Epiphany2000. That is helpful. The car is in Virginia and it has new tires. I might need to take the same chance you took - hopefully with the same positive results.
  5. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    It may not have sat unused. My 2007 just turned over 45k miles but it gets driven at least once/week. I think its HV battery is pretty happy--it's almost always in the insulated garage, doesn't hard-cycle too often. It works just like new.
    I think most of the car's components benefit from the reduced wear of not being driven too much. You (and I) might not get as many miles from the HV pack as the frequently driven ones, but the rest of the car should be in good shape. If I get 80,000 miles from the HV pack, I'll be thrilled (that'll take me another 17 years).
    Bluetooth was part of package 6 in 2005--top of the line!
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    There have been a few low mileage cars that have had Traction battery problems. So some of us think age plays a part in battery health equation. My suggestion is you not pay a huge premium for the low mileage.
  7. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    For sure the 2005 has Bluetooth, mine does.
  8. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    I bit on an '05 with 43k on the clock. Full service history, short dealer offered warranty due to low mileage. Everything seems to be in good shape. And I'll second the Bluetooth as our pkg 6 has it as well. Can't figure out the phone book transfer yet but it's all there. Good luck whatever you decide.
  9. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    If it is a clean car and a fair price go for it. A grid charger from HybridAutomotive.com would be a great investment to extend the life of the HV battery.
    The bluetooth works great for phone calls. That is the extent of it, it doesn't stream music and phone book transfer requires hooking up a laptop. Just dial from your phone.
  10. 3MCS1DJ
    3MCS1DJ New Member
    Richmond, VA
    Thanks everyone. Much appreciated. I just got home from buying my first Prius. - this 2005 mentioned at the beginning of this thread. I couldn't pass it up. It literally looked brand new inside and out. Zero stains or wear and tear. The paint is like new. It has been in Virginia (not on the coast) since new and always garaged. It didn't have a single rattle in it. 4 new Michelin Energy tires with less than 3K on them. 67,844 miles and a very fair price. Half a tank of gas left and the car is averaging 50.7 MPG. Not sure if this MPG is good, bad or just on par. But I am very happy with this MPG and the car.
    Data Daedalus and Mendel Leisk like this.
  11. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    You did fine!
    3MCS1DJ likes this.
  12. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Sounds great. :D
    In theory it is, because it's not good for the cells undergo significant discharge via self leakage as opposed to real usage. In practice however using the Prius just a couple of times a month would be plenty to prevent any problems. Even at only 67k miles, your car has still been driven over 140 mile per week on average. I think it's very unlikely that the battery sitting for too long will have been a problem. :)
    3MCS1DJ likes this.
  13. elemare
    elemare Junior Member
    North Providence, RI
    3MCS1DJ, I owned a 2006 (RED!) Prius with only 49,500 miles on it and I drove it every day. I just don't have to drive much - my commute is only about 16 miles a day. I LOVED that vehicle and it was so reliable and good to me. It was totalled by a 17 year old driving a Nissan Frontier who ran a stop sign and crushed the passenger side 3 weeks ago. I have been heartbroken ever since.
    Best wishes to you for a long and happy relationship with your new old car!
