Getting that new Prius smell back
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JB88, Jul 9, 2014.
  1. JB88
    JB88 Junior Member
    I've had my Prius for about a year and keep sports officiating equipment in the back. I find it hard to keep the car smelling pleasant.
    Does anyone have any recommendations for car fresheners? I'm not one for something tacky hanging from the rearvew.
    Appreciate your suggestions!
  2. Mendel Leisk
    41,705
    Open all the doors and hatch and have at it with a leaf blower?
    I sometimes do that as a final step after vacuuming out the interior. Especially when I've started noticing a cobweb or two.
    Also, do you use AC a lot? Could be something growing in the ducts/tubes, there's a lot of moisture in there when it's been running.
  3. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Are you surprised that if you put and keep stinky stuff in your car that it smells bad?
    I doubt that there is a product strong enough to "remove" all those odors.
    I'd try removing them and/or sealing in bags.
    Mike
  4. JC91006
    JC91006 Senior Member
    16,795
    8,589
    2 easy ways to tackle this problem.
    1. Get a "hanging tree" type of freshener, but put it inside where your cabin filter is located. Make sure it's held between the filter and the filter housing....that way you get fresh air without anything hanging.
    2. They now make air freshener clip on devices for your air vents. Febreeze has them, Costco has another type, simple and effective.
  5. sprtent
    sprtent Member
    104
    75
    SF Bay Area
    In my previous car I securely placed a cut-open-top baking soda powder box in the trunk.
    If your 13's Four has Solar, I think it would also help to use the baking soda type of carbin air filter.
  6. DrPepperholik
    DrPepperholik Active Member
    342
    108
    Spartanburg, South Carolina
  7. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I assume you're talking about mask, vest, shoes, etc.? Do you wipe them down with Lysol wipes (or something like that) after each game? Do you leave them in the car over night? If you do, I suggest you add a tray of baking soda, maybe in a Tupperware container with holes punched in the top. Do you just put the stuff in the back or do you put them in a closed storage bin with an air freshener clipped/taped to the top?
    JC91006 likes this.
  8. JC91006
    16,795
    8,589
    Closed storage bin....what a great idea!
  9. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Just don't forget some baking soda or something to keep them from reeking before you take them out. Of course, if they're just in there for the ride home after the games, probably not needed. My daughter has boys who play baseball and their equipment is really odorous after a tournament. All the stuff is in ball bags, so the small still permeates into her trunk. :)
  10. ibmoses
    ibmoses Junior Member
    109
    22
    Fabric softener sheets like you put in clothes dryer, try it.
  11. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Hanging from the mirror of my 10 Prius is a little blue pine tree shaped air freshener labeled "New car smell".
    It's pretty close. ;-)
  12. priusdonkey
    priusdonkey Member
    211
    51
    Los Angeles, California
    chemical guy's makes a spray. i believer i have watermelon they also have stripper (pole) scent?. lasts about 2 weeks and the bottle will probably last 10 years.
  13. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    I find that my cars tend to spiral downhill (odors and over all junkie ness) by letting things, in general, accumulate in it. I coached soccer for years and was able to keep my gear stored in the trunk. With my Prius being a hatchback I no longer have this luxury. I take my gym bag out, and most everything else, at the end of the day. It also makes it easier to shake everything that tends to collect on the floor mats that add to the dank smell.
    Another thing. Occasionally wipe the dash down with a cloth dampened with lemon Pledge. You can keep one sealed in a ziplock Baggie in the glove box. I use it on everything most would use armour all. Not nearly as slick and shiny. I use it on everything from CV joint boots, dust boots on bolts that hold disc brake calipers on, guitar fretboards, amp coverings, anything rubber, plastic or vinyl.
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I use Ozium Air Sanitizer spray.
    It's available almost everywhere.
    What I like about it, is it works #1, and more over, it's a fine, fine mist, so when you spray it you don't feel it is floating down on everything.
  15. fuzzy1
    10,533
    ... if you like your sweaty stuff to turn moldy and mildewy and even more icky, at least in my climate.
    Removing the stuff from the car each evening, and airing it out somewhere, is almost essential here.
  16. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    In the time it takes to drive home? Even my grandsons know to take the stuff out of their ball bags when they get home and clean it before they use it again. :) We're not talking about storage, we're talking about getting the equipment home without the odors messing up the car.
  17. fuzzy1
    10,533
    No, I believe OP and others are talking about storing these things inside the car. If the sweaty items were removed nightly, I doubt there would be a problem.
  18. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Tell that to my daughter and the boys' baseball gear (catchers) that only stays in the car for the ride home. But, you're point is taken. I would not store any gear in the car, much less in a closed container, without something inside to avoid mold, mildew, etc.
  19. priusdonkey
    priusdonkey Member
    211
    51
    i have seen small cargo boxes that attach to the tow hitch. I have a receiver hitch for my bicycles, but i know they make aluminum boxes for the receiver hitches. harbor freight sells an aluminum one.
  20. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    If wonder if the OP has tried any of the suggestions that have been offered?
