How to delete a previous destination
Discussion in 'Gen 2 Prius Main Forum' started by Three60guy, Mar 18, 2006.
  1. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    Racine, Wisconsin
    The GPS system in the 2006 Prius creates a list of previous destinations that are used for later quick recall. How do you delete one of those or all of them? I am not talking about the memory points. The memory points can be deleted easily. I just haven't found the way to delete one or all of the items in the "Previous Destination" list.
    Anyone have any suggestions? No, it is not in the manual. I have already looked.
    I appreciate any ideas or suggestions.
    Cheers
    p.s. The list I speak about above is observed by first hitting the DEST button then clicking "PREVIOUS".
  2. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    2004 Navigation System Owner's Manual - pp 91-92
    2005 should be same or close
  3. Three60guy
    918
    Racine, Wisconsin
    Does anyone have 2006 info?
  4. Three60guy
    918
    Racine, Wisconsin
    Please remember, I am asking about how to delete the "Previous" list after you hit the Destination button. The info on how to delete memory points is totally different.
    Try to delete the "Previous" list. I can't yet.
    I would appreciate any help from users here.
    Thanks.
  5. KMO
    KMO Senior Member
    2,009
    731
    Finland
    2023 Prius Prime
    On the 2004, you press the MENU button by the screen, go to "Setup", and somewhere on that big menu there's a "Previous destinations: Delete" button. It'll probably be somewhere similar on the 2006.
  6. Three60guy
    918
    Racine, Wisconsin
    Thanks for replying......however......
    There isn't one of those for deleting Previous Destinations. It allows you to delete memory points but not previous destinations. There is a difference.
    Have I come across another 2006 bug/glitch?
    Any other 2006 owners confirm this?
  7. TheForce
    3,461
    537
    Wheelersburg, Ohio
    If I remember I will try to find out where to delete those when I get home tonight. I do remember deleting previous destinations somewhere but I cant remember where.
  8. KTPhil
    KTPhil Active Member
    1,379
    22
    Where did you navigate to that you don't want your spouse to find out about?
  9. rmblaster
    rmblaster New Member
    Orange county , CA
    Hit menu then my places and at the bottom of the screen is a button delete previous points hit then confirm that should do it
    Rich (another round guy)
  10. Three60guy
    918
    Racine, Wisconsin
    Nope, that doesn't do it. Try it. Memory points are what you are referring to. I was referring to "Previous Destinations".
  11. Three60guy
    918
    Racine, Wisconsin
    KMO, you were right after all. I hadn't read your instructions properly. Setup, indeed has the delete previous destinations option.
    Thanks.
    Edit......
    I was reading a 2005 owners manual (pdf format) when I agreed with you. I just discovered that they moved this function to the "My Places" of the Menu screen. There is a big button at the bottom of the screen which clearly states "Delete Previous locations". This was confusing because above that they were talking about memory points which is totally different. In any case, you can delete one or all previous locations.
    Thanks everyone for their help.
  12. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    I am looking at page 53 of the 2006 NAV instructions for deleting destinations. The procedure is 1. Touch "Route" on the Map 2. Touch Delete in the screen which comes up 3. Select the destination to be deleted on the screen which comes up 4. Click OK.
  13. KMO
    KMO Senior Member
    2,009
    731
    Finland
    2023 Prius Prime
    That's for deleting current/future destinations on your current route, isn't it?
