Non JBL to JBL Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TJ_Boone, Jul 15, 2014.
  1. TJ_Boone
    TJ_Boone Junior Member
    Boone, NC
    I have a new-to-me 2008 Prius (package 2 I think). The CD player doesn't have MP3 or Aux capabilities.
    I have found some used JBL radios cheaper than the more enhanced non JBL radio. It is my understanding that the wiring harness doesn't match, I don't have a BT mic, and that I don't have an amp. MP3 and Aux is my goal.
    Questions:
    - Would it be much trouble to make a adapter for the harness for the JBL radio?
    - Would the JBL radio damage my non-JBL speakers?
    - Do you have other suggestions for getting Aux and possibly MP3 for under 70 dollars?
    Thanks!
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    the jbl has an integrated amp under the rf seat. it would be difficult to rewire the car for the jbl. the good news is if you install an aftermarket head unit and speakers, you will have a better system than the jbl, which isn't all that great. there are several threads on this. I had a kenwood in my '04 and I replaced all the speakers with bigger, better 4 ohm drivers. it sounded very good-- much better than the jbl in my '06 or the wife's '05. also, alpine tweeters fit the front door triangles perfect, and sound great. in many ways, I like the base stereo better because its so easy to upgrade. the jbl uses odd resistance drivers, so its hard if not impossible to find correct resistance drivers to replace the mediocre jbl. 4 ohm woofers might maybe work, but no one has had any luck with that that I've seen.
    there should be an aux port in your center console, next to the 12v outlet.
  3. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    If you just install an amp and sub and speakers, it will far exceed anything JBL puts out. Leave the head unit alone.
  4. TJ_Boone
    Boone, NC
    I don't have a Aux next to the power outlet in the center console.
    If I get the MP3/WMA radio, I guess, I would need to place an Aux port somewhere. I would think that the wiring is likely under the center console, but I would have to drill a hole in the console and wire it correctly to a jack. Anyone have an idea if the wiring is there?
    Thanks for the input. You people are awesome.
  5. 69shovlhed
    2,170
    748
    Delaware
    the head unit sounds like dooky, and there are no aux or usb ports, or BT.
    some aftermarket head units have the aux and usb ports right on the front. no drilling needed. a good head unit and door speakers will be fine without a sub unless you have room for it and require massive bass. you also need the metra axxess so your steering wheel buttons will work, and a scosche install kit. crutchfield can hook you up, but they will try to sell you some dinky little woofers, or coax speakers. I got my woofers from parts express. 7" in the rear doors and 6.5" in the front.
  6. Husker Prius
    Husker Prius New Member
    25
    Firth, NE
    I think there are easier ways to add an aux connection. I have the non JBL stereo in my 2007 and I picked up a GTA iPod integration unit for a good price on eBay. It works for apple products and uses the steering wheel controls, but also has the 3.5mm aux input. I have the aux input in the center console, but wanted to use my iPhone or iPod also. It took about 10 minutes to install through the glove compartment and gives great sound through the iPod. I thing regular price is $99, but mine unused was under $50 thru a private party on eBay. They are other units, but this was a good value for me.
  7. TJ_Boone
    Boone, NC
    That sounds like a great solution Husker. I may go that way eventually. I did get access to a MP3 and aux radio on ebay and installed it. Didn't take as along as I thought. Works great. I decided not to go with the JBL per everyone's warnings. I really appreciate the headaches and $$ you all are saving me on wasted time and parts.
    However, I still have to set up an Aux jack.
    I found an adapter/plug underneath the center console. It has five red wires in it (attached). Would this be for the Aux jack in the center console?
    Thanks again!
  8. TJ_Boone
    Boone, NC
    Anyone had their center console up and recognize this plug?
  9. defrankond
    defrankond Member
    217
    North Dakota
    i almost wonder if that is the harness for the 12v plug that normally would be in the console.
  10. TJ_Boone
    Boone, NC
    Thanks for the response. The car has the 12v plug already in place and functional. This wire is additional.
