Not driving for a few?
Discussion in 'Gen 2 Prius Main Forum' started by exmetrodriver, Jul 18, 2014.
  1. exmetrodriver
    exmetrodriver Member
    124
    Puget sound, Wa.
    I'm a 3 car owner. Will I run into starting problems not driving my prius for a 2-3 day period?
  2. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    No, the battery should still have enough power to start the car after 2 weeks. Deep discharge cycles will shorten the life of the 12V battery, so if parked for more than a week, I would connect a battery maintainer to keep the 12V charged.
    The Prius 12V is an AGM type deep cycle battery. Make sure any battery maintainer you consider is safe for AGM type batteries.
    I use a BatteryMINDer brand charger/ desulfator/ maintainer sold by Northern tool. A very good unit to maintain a Prius battery. Mine has the optional wiring harness so it can be hardwired to the battery and stored in the under floor tray.
  3. Mendel Leisk
    41,333
    Our typical use is every second or third day. No problems.
  4. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    No problems at all. Mine often goes over a week between drives.
  5. exmetrodriver
    124
    Puget sound, Wa.
    So if I went on vacation for 10 days would it be advisable to disconnect the 12V battery?
  6. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    Just turning of smart key system should be enough.
  7. exmetrodriver
    124
    Puget sound, Wa.
    I have the basic model. No smart key....... so I should be good. Thanks
  8. Patrick Wong
    18,200
    6,500
    All of the above discussion assumes your 12V battery is in great condition. If not then you very well may have a no-start problem after 10 days. It would help for you to fully-charge the 12V battery prior to your storage period.
