Plug-in Prius Battery Upgrade
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Ben@Boston, Jul 3, 2014.
  1. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Do you have a link to the numbers (spreadsheet?) you're using? Everything I've seen implies the opposite, unless someone isn't using comparable cars (eg a Mitsubishi Mirage base vs a PIP base), but even then it can be pretty close given the price Toyota has been selling their PIPs for recently.
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    I don't think I've saved the spreadsheet, but seriously, how complicated is it to calculate?
    I assumed a 2 liter per 100 km saving with the Prius vs the Corolla (conservatively). Assuming any inflationary increase in fuel costs per year, that's about $2.20 per 100 kms (adjusted for today's dollars). In order to get that $7000 (hybrid no-rebate, premium) back, you to divide $7000/2.2*100= 318,100 kms = 197,596 miles.
    #62 GregP507, Jul 19, 2014
  3. bisco
    51,840
    ben must be busy installing those large batteries he found online.
  4. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I don't get the same numbers, but they're close. I see a Corolla LE at $18300 versus a Prius II at $24200 (similar features, the base Corolla is really striped down), so a difference of $5900. Gas savings would equate to a difference of ~$6200 over 200k miles. Given gas prices in Canada, that payoff period would be ~150k miles.
    In addition, you're comparing a compact car to a mid-size car, and I think the mid-size car has more in the way of options, so it's not an apples to apples comparison. Shoot, you could compare a new Prius to a 1981 VW Golf diesel, or a bicycle, but that's not what most people consider a reasonable comparison. With all that aside, what I really don't understand is how the larger car having fewer expenses over ~150k-200k that isn't considered paying off itself in most cases.
  5. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    without the inventors pushing the envelop and the manufactures to keep pace with new technologies
    we would still be driving at 20 to 30 mpg and standard oil would be that much more profitable.
    And a lot of those inventors work out of there garages for a bunch of reasons.
    But if one doesn't trust or has misgivings about a project for whatever reasons, then I think it would be wise not to support that project.
    #65 vvillovv, Jul 22, 2014
  6. LA2014Prius
    LA2014Prius Junior Member
    103
    2014 Prius Plug-in
    Depends on how often you can charge. My commute is about 18 miles each way and I can charge at work now. My MPG is over 100MPG... Actually 100-150MPG depends on how I drive; and this include weekend that I can't charge once I leave the house for more than 100 miles drive.
    My last tank, my MPG was 106.6MPG !!!
  7. hill
    8,792
    They went bankrupt - in part due to failures in quality.
    Best not to gamble. A fire is evidence of a lack of required build understanding/caution & skill. However, there ARE some talented EE's in our group ... and Phill (pEEf) can show how well the job can be done. He not only built a great system, he built his own controller, as well as thermal management system.
    Update and technical details on my PHEV project | PriusChat
    IIRC, he's getting an easy 25 miles of EV range, w/out having to upgrade suspension ... which would have further compromised range, more than just the extra battery weight.
    #67 hill, Aug 14, 2014
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,422
    3,294
    Madison, Wisconsin
  9. GregP507
    3,002
    481
    A lesson from WWII: Early in the war, German equipment was vastly superior to what most other countries produced. The Allies were scrambling to produce something equivalent to what the Germans had. Later in the war, it was the Germans producing machines that failed on the battlefield, due to them being rushed into production too quickly, without adequate time for testing.
    The lesson of this? Testing makes all the difference. Amateurs have neither the time nor the expertise to match the extensive testing being done by the auto-makers.
  10. hill
    8,792
    EDIT:
    Oops ... yes. I was thinking the Enginer system/kit - and their quality issues.
    With the conversion folks down the road from us at 'Jungle Motors' copying a similar name (same acronym) ...
    Problem with Jungle Motors | PriusChat
    I can hardly keep the conversion folks straight. And it's a drag when honest companies get associated with the dishonest ones. And while I'm editing - there's a nice description of who some of the parties are (were) who have come & gone:
    Competitors | Plug-In Supply
    I'd LOVE to get that mongo 15kWh pack for our Lexus 400h hybrid SUV. Big bucks. Maybe some day.
    #70 hill, Aug 22, 2014
  11. ericbecky
    4,422
    3,294
    Madison, Wisconsin
    hill, I'm still pretty sure you meant Enginer, not PIS. You may want to correct it in your post #70.
  12. hill
    8,792
    Dang yes if I didn't do it again - I'll go fix it
  13. Bill Norton
    Bill Norton Senior Member
    2,143
    734
    MONW, Ks.
    Ben,
    If you want more EV performance you should consider a car with more EV performance engineered from the beginning.
    Don't add a patch to your PiP. Li-ion batteries need Thermal Management to be safe and last a long time.
    The normal Prius had a patch added by the factory.
    That's where the PiP came from. And it has a very minimal TM system (a fan).
  14. bisco
    51,840
    i think you missed ben's post on trading the pip for a tesla.;)
  15. Bill Norton
    2,143
    734
    MONW, Ks.
    Yes, I missed that, sorry. But I still don't see him mentioning a Tesla anywhere.
    A B/A BEV is a whole different story.
    But you still can't go anywhere at anytime with one of those. If you have a second car those might work for you...
  16. bisco
    51,840
    he tried the large batteries he saw online, but they just didn't work out that well. tesla made more sense, no heavy lifting.
  17. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Hmmmmm - this all sounds familiar. We're not going there again, are we Bill? There IS another venue for Volt discussion.
  18. Bill Norton
    2,143
    734
    MONW, Ks.
    The OP was asking about an add-on battery for a PiP.
    If done properly this sounds like a great idea! Have any of the battery kit businesses installed in a PiP yet? Prices?
    The PiP (vs. the Prius) already has the SW allowing decent 3-season EV performance. Adding an extra battery pack could easily double EV range.
    If the performance of a PiP suits you, this is a viable option for a PiP that is out of warranty.
    ( Or, installed so it can be removed without a trace before any service visit...)
    The one difficult item for this installation might be plumbing TMS hot air out of the cabin, or not.
    The OP should start on his Solar Installation now!!
    I'd wait for one of those shops to design and test a kit for a PiP.
  19. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    The regular Prius comes with a 60 kW electric motor, yet it has a small battery-pack which only delivers a fraction of that. How do you explain such obvious under-utilization?
    Toyota built a system that could be upgraded when cost of the battery dropped to a competitive level. The strategy of planning ahead to minimize financial risk and to fully test the system ahead of time is called good business. Calling that a "patch" is inappropriate.
    We can clearly see how the extra power from the larger battery improves the regular Prius without having to do anything other than the pack upgrade itself. It's a package option, in a market where using electricity is still a niche and is still dependent on tax-credit incentives.
    #79 john1701a, Aug 24, 2014
  20. Oscar Radikoro
    Oscar Radikoro Junior Member
    United Kingdom
    ----UK----
    "nice oscar" is my name on YouTube. I added a range extender battery pack on my plug in prius and nothing changed! It takes long to charge but the range is almost the same. I built a pack using Tesla Battery Module. 7p56s, (3.7v, 3.3mhA each cell), (207.2volts, 23.1A battery pack) which is 4.7kwh battery. The ev range has not improved much.
    I did this because I want my plug in prius to be a 5 seater 50-80 miles EV and engine run at higher speeds. Nothing is working according to plan so far. I don't have any error codes.
    Pluggo likes this.
