A/C cabin blower not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gary renelt, Jul 17, 2014.
  1. gary renelt
    gary renelt New Member
    byron, CA
    My 2005 with 240,000 miles
    I have changed the blower motor once already, about 60,000 miles ago. It fan has been working intermittently, but has recently stopped completely. I ironically had the battery replaced on the same day (morning) tht the blower stopped. Because of the intermittent operation, I don not think a fuse is the culprit. I stopped at a dealer and the service manager, because I couldn't leave the vehicle suggested that I may be a relay. Any thoughts from anyone? thanks for the help....
    also, wth the outside air flow option on, I am getting cold air trickling through the vents.
    #1 gary renelt, Jul 17, 2014
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved out of technical.
  3. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Sounds like it needs to be replaced again.
    Did you replace it with new OEM, used OEM or aftermarket. How often have you been changing/cleaning the cabin filter? Do you park under a tree where it is always full of leaves?
  4. gary renelt
    byron, CA
    I believe it was aftermarket - I am a smoker, have changed to cabin filter about every 50,000 - blow it out with compressed air in between changes. No trees nearby when parked, but we do have ag around us so certain times of year the dust can kick up. What might the cabin filter have to do with the fan motor working?
    Thanks for your response.
  5. Patrick Wong
    18,210
    6,517
    To the extent that dirt or smoke particles are circulating around and getting past the filter into the fan, that might cause the fan to fail sooner vs. later. When the fan is removed (if you don't do the work yourself) ask for the part to be saved so you can look at it.
