brake system warning
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by valuequest, Jul 25, 2014.
  1. valuequest
    valuequest Junior Member
    southeastern Virginia
    At just about 21800 miles and 19 months service this morning the brake system warning light came on. This is the yellow brake system warning light, not the red brake warning light or the generally similar looking yellow low tire pressure warning light. No other warning lights are on in the service indicator panel. What troubleshooting can I do myself before taking it to service facility?
    #1 valuequest, Jul 25, 2014
  2. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    I'm confused as to which light turned on. Pick a color of rectangle please.
    ztanos likes this.
  3. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    Not much you can do without a higher-end scan tool. Regular code reader isn't going to tell you what's going on with manufacturer specific codes.
  4. kinkinhose
    kinkinhose New Member
    Eugene, Oregon
    White rectangle.
  5. bisco
    52,341
