Cheap cargo cover?
Discussion in 'Prius c Accessories and Modifications' started by highroller, Jul 23, 2014.
  1. highroller
    highroller Junior Member
    79
    I have a prius c one 2013. It does not have a cargo cover. Where can I buy a cheap cargo cover? I am currently using a tarp, but it doesn't look good.
  2. xliderider
    xliderider Senior Member
    8,045
    3,218
    Honolulu, HI
    Maybe search at a salvage yard for a wrecked c?
    SCH-I535
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i believe for the c 1 it will be hard to add a cover since it has soft panels in the trunk where as the higher models have hard molded plastic in the trunk sides.
    xliderider and ztanos like this.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    You have to change the panels in the trunk area on the c1 in order to have the holders.
  5. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I paid 69.00 for one that fits the c 2 perfect. Got it from a dealer on eBay. Has Prius C embraced on it.
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Didn't the model 2 come with one?
  7. highroller
    79
    Any creative idea that does not require the molded plastic?
  8. Caries
    Caries New Member
    San Francisco
    2014 Prius c
    Unfortunately, Toyota seems to be going along the same road of manipulating the consumer into buying the higher version so they make more $$$$. The side panels of the cargo area in cars with Option One is such that no after market cargo cover will fit. Toyota is simply pushing you to buy their more expensive option packages. "Free economy" 1-Consumer 0.
  9. WD0AFQ
    619
    152
    Dexter, Mo.
    The 2 came with the carpet one. We bought the rubber one to put back there for hauling stuff that might leak.
    Dan
