Can't think straight about gas tank.
Discussion in 'Prius v Fuel Economy' started by bikeboy999, Jul 22, 2014.
  1. bikeboy999
    bikeboy999 Junior Member
    43
    Ottawa, Ont.
    2015 Prius v wagon
    I was at a gas station yesterday, and immediately the pump stopped pumping. So I had to pump in amount of gas by guess. Now I am wondering if my stats re: gas in for miles driven are off. And if off will it correct itself if next fill up will have properly working pump? BTW I checked the gauge and it was at the top, so I think I guessed close. And it showed 5.2l per 100km in my app.
    So am I thinking straight or not? My l per 100k are off on this fill up?
    Brian
  2. JC91006
    JC91006 Senior Member
    16,762
    8,562
    I can't think straight after reading your post :confused:
    vvillovv likes this.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Gas pumps are all inaccurate to some degree, which is why its best to always use the same pump or at least the same gas station.
    As for the "effect" of one fill at a wonky pump, it really doesn't make any difference in the long term Use Fuelly or some other tracking system to track fill-ups over the months. You've still used x gasoline over y miles, so it will average out. The only thing that screws the stats is if you pump gas onto the ground.
  4. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    I refuel at three stations mostly. One station I refuel at typically allows more fuel before shutoff. It could be their sensor, the temperatures, or the slight downhill if I drive in a certain way. I've never actually tracked the particulars, but when I refuel there, my calculated milage is down more than the computed mileage. Unfortunately, I don't have the data to correlate the actual differences. My last tank showed the displayed mileage to be 2.5 mpg higher than calculated, while my other fills were closer to 1 mpg off. This last tank used was from one of the other stations, which appears to have led to the higher than normal discrepancy.
    But we're talking about a difference of .6 gallons, so this is not remarkable.
  5. schmuly
    schmuly Member
    209
    51
    BC
    Hey Brian, Some pump nozzle have a slight different curve so when you stick in your tank the flow hits the side and if any resistance it will shut the pump off. I usually pull the nozzle out about 3/4 inch to minimize this effect . Now most nozzles in the US you have to push the nozzle in to create a pressure seal, but I have never seen it in Canada. Also some vehicles have different curvature in their piping so pulling it out a bit doesn't always work. It is not an exact science .
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I set the nozzle at the lower flow rate. That usually prevented premature shut-off.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I do both of the above to prevent the shutoff issue, do not insert fully and set to the lower flow rate. Works for me.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    I only saw the issue in the cold winter. I'm surprised it pops up in NC
  9. jdcollins5
    5,131
    1,346
    Wilmington, NC
    It seems to depend on the pump sensitivity to me and not necessarily the weather. After having this happen a couple of times I just automatically do the above and have not had any other issues.
  10. Mendel Leisk
    41,334
    I think you just got unlucky, got a pump with malfunctioning shut-off. I'd:
    1. Notify the station manager. Basically so it gets fixed.
    2. In future just pump gas normally. This was a one-off, not a common occurrence.
  11. Oxy
    Oxy Junior Member
    Australia
    2014 Prius v wagon
    I had the same thing happen to me yesterday (went to a different petrol station) so pulled the nozzle out by about 2 cm and hold the trigger a little less tightly to lower the flow rate. In past 2 fills I was satisfied to stop after the second click, but this time I had to makes sure and it took about 5 clicks. No spills thank goodness. Yeah you can't be precise as there are a couple of factors we don't know. The pumps are probably variable in accuracy, and we fill up to "full" though we can't see how full. But choosing the same petrol station most of the time and making it a rule to fill up and stop after the second click (or third click if you choose) helps to make the average more accurate. Anyway 5.2 is what I am getting now.
