Explaine how the heater works
Discussion in 'Prius c Technical Discussion' started by gbouten, Nov 23, 2013.
  1. clgutierrez
    clgutierrez Junior Member
    51
    17
    Rob
    looked for PTC heater in the Prius C service manual and found a note stating that it is present in "cold area specification models", seems not your case nor mine (Chile)
    Sent ?
    Rob.au likes this.
  2. type17volkswagen
    type17volkswagen Junior Member
    66
    Northern Virginia
    THANK YOU. I researched this before buying my C. This is my first winter with it so I read the manual but didn't figure it out. I tried your settings today and they worked like a charm. No more cold mornings - all thanks to you!
    I had a Golf diesel before this and it had an electric heater. I liked that it would make audible clicking noises under the dash when the element kicked on and off so I knew exactly when I had gotten the temp and fan to just the right position to trigger it. No such noises in the C.
  3. mdgates
    mdgates Junior Member
    67
    Buffalo, NY
    Ah. That explains why I have never seen, and will never see, this behavior. :)
    Rob.au likes this.
  4. Mark323
    Mark323 Junior Member
    69
    I heat my cabin with the electric seat heaters... lol
