Really leaning toward a 2014 Prius Plugin, need your opinions/thoughts
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by inferno, Aug 3, 2014.
  1. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    Every time I read a positive review of the Ford Fusion Energi or Honda Accord Plug-in I'm forced to remember how much the battery has compromised the trunk space.
    52,351
    agreed. i would love for my wife to have a plug in camry, but it would have to be designed in a way that allowed for a decent trunk.
  3. srl99
    srl99 Member
    113
    2014 Prius Plug-in
    The base PiP was 26K (after 3K Toyota rebate, should waited 2 months for 4k!), the PiA was 40K. There was nothing to justify the extra $'s.
  4. abistro
    abistro Junior Member
    22
    Virginia
    Actually, I love it and the MPG is 39 because Ford had to revised it twice already. However, I think that's mostly due to the driver. I've been driving the Ford like I drove the Prius (slow acceleration, coasting, etc.) I actually get comparable MPG ~ 48-50 MPG on hybrid mode. It all depends on how you drive. The Ford has a bigger engine, 2.0L compared to the Prius's 1.8L. It has a little bit more power 195 HP with both engine running vs. 134 HP on the Prius. With more power comes more fuel consumption.
    When we go on trips, the ride quality is much better, it is a bigger car (Camery size). However, as some have already stated, trunk space is very limited to a 2 small suitcase. It's not a car for everyone, but for me and my 14 mile round-trip daily commute, it works out great with spare miles for running errands around town on all electric.
    SageBrush likes this.
  5. abistro
    22
    Virginia
    Agreed, I really wish there was more trunk space. However, this is my primary commuting car and short trips. Wish they'd put the battery on the bottom of the car, like Tesla :p
    #45 abistro, Aug 5, 2014
  6. bisco
    52,351
    if someone can accomplish that, they'll have a real winner. at least for us, that would cover 95% of my wife's mileage.
  7. Tideland Prius
    16,610
    Just because they can, doesn't mean they will. I believe Toyota is trying to reduce the cost and offer a price-competitive PiP. Their dilemma is: More EV range, same (or higher) cost? or Same EV range and lower cost? I think Toyota's trying to go with the latter. I believe the current market wants the former. However, what happens when the current market is satisfied? How would Toyota draw in other people that aren't early adopters that want a plug-in but the high price is prohibitive? Toyota has to anticipate the market 2 years from now and plan for the life of the next gen (so effectively what's the market like between 2 years and 8 years from now?). Will the PiP be competitive if it offered the former? (esp. with GM and Nissan lowering the price of their EVs/EREVs).
    I suspect Toyota will offer 4WD-i in the regular Prius and keep the PiP as FWD only. Will a PiP AWD sell? Possibly but they need sales numbers vs. cost of producing it and they have to satisfy the big boss that it's a viable option. Again, I suspect the market is small. An AWD Prius Liftback would be a much easier sell to the boss as it will be the only AWD full hybrid (the XV CrossTrek is a mild hybrid, right? and technically a compact) midsize on the market and the Prius brand/name helps sell it too as well as clientele - I believe Prius owners tend to be a bit more outdoorsy and adventurous than your typical Camry buyer, no? It'll also help differentiate it further from the Camry Hybrid.
    In Canada, the Camry Hybrid is outselling the Prius (surprising since we tend to prefer smaller cars) but I suspect the value-equation favours the TCH at the moment. If the Prius is offered in AWD, it will sell in Canada. I'm meeting more and more people that are adamant that their vehicle have AWD and will not consider a 2WD vehicle. An AWD hybrid will sell (e.g. RXh) and I know at least Lexus Canada is clamouring for an AWD hybrid sedan. I'm not sure about Toyota Canada's stance.
    Sorry for the off-topic.
    My suggestion? Pay off the 2010 Prius and the money that you would've used for a 2014 PiP payment, put that aside in savings and use that as a downpayment when the time comes (end of 2016 apparently). That way you can decide on a 2015 PiP or factory order a 2016 and with reasonable downpayment in hand, you may be in a better position to negotiate.
    Sergiospl likes this.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Error on my part ...
    The AWD talk from Toyota was wrt to the Prius, not the Prius plug-in.
    This does not mean it is not possible, only that I have not read anything specific.
    It well may be that Toyota kinda sorta gives customers a choice between AWD or extended range EV in the higher price trims. It would certainly be consistent with how Toyota has offered leading tech items in the past.
  9. bisco
    52,351
    dianne says larger battery, higher price. i don't know how 'inside' her inside information is.:cool:
  10. inferno
    inferno Senior Member
    1,072
    405
    Higher price? But Toyota says new hybrid system and TNGA will lower prices :p My guess is same price higher ev...I hope AWD
  11. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    There is the reality of tax-credits no longer being available then.
  12. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    I suppose it's possible Toyota could have cheap PiP and an expensive PiP with bigger battery.
    Recall a couple years ago it was thought that Plug-In woud be standard on all Prii.
    The next PiP will have the inductive charging option and that sounds like a more expensive car to me.
  13. bisco
    52,351
    i hope it's an option, not something i would be interested in, especially at a cost. hard to believe that will be available in two years.
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    Ditto!
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    According to WiTricity, the cost should be around $1,000. The price could be $2,500 - $3,000 but it is really up to Toyota.
    Charging efficiency is 90%+ from end to end for PHEV application (AC in and DC out).
    I think Toyota should bundle the wireless charging option with the Smartkey. It'll make plugins really convenient.
  16. bisco
    52,351
    ouch, i want my sks, no more bundles!:cool:
  17. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    It might lower prices to them, but I highly doubt consumers will see a drop in price. And where is all this AWD speculation coming from?
    I also hope they make it an option, although if they plan to increase it's adoption they'll need to include it on all models. But that will definitely increase the cost as well. It seems convenient for a closed garage, where you can leave the pad permanently on the floor, but I'm not sure I would like to leave it outside on my driveway where I normally charge my PiP, and if it gets pushed to the public infrastructure then ICE'ing will make it impossible to use, and you can't unplug someone who finished charging next to your spot and plug yourself in (or vice versa).
    I tried out the technology for my Nexus 5, and was so unimpressed I returned the wireless charger. Generated more heat and charged slower and needed to place it properly on the pad, not worth saving the hassle of simply grabbing a cable and plugging in IMO.
  18. CharlesH
    2,797
    1,165
    Roseville, CA
    I have the Tylt charger for my Droid Maxx, and I just toss the phone onto it, and it works, charging about as fast as a USB charger. I understand that other wireless chargers can be fussy about positioning, but the Tylt shows that this is not an inherent issue.
    I also hope that the inductive charging system on the PiP would be an independent option, not bundled with something else like the SKS.
  19. JBumps
    JBumps Member
    167
    57
    Morgantown, WV
    2013 Prius Plug-in
    You could always find a gently used and we'll cared for 2013 PiP for much less than new. You might even be able to find a nice one on these forums for around $21,500 ;)
  20. inferno
    1,072
    405
    Welp guys, just to give an update we decided to stay with my 2010 Gen III Prius. There was a needed maintenance cost of 2 wheel bearings which cost about $1,100
    I hope nothing else happens, already poured over $1k into the car the past year including tires, replacing a tire, etc...
    Sheesh! However, with new wheel bearings it seems to drive like new!
    BTW, we did look at used cars and wow there's like a $10k difference in the new model and last year's...No credits or anything though.
    For now we'll try to finish the payments and rundown the car. Of course in that case it may take 3-4 years. Hopefully the Gen IV is out by then ;)
