2009 wont' start or shift out of park (merged)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius Newb, Aug 3, 2014.
  1. JC91006
    JC91006 Senior Member
    16,759
    8,562
    Where are you putting the negative cable when jumping? Positive in the fuse box, negative where?
    New battery should be around 12.9, but yours will probably arrive at around 12.5. If it's not 12.5 or more, you might want to return it to avoid issues later
    51,798
    12.9 volts out of the box before you install it. if it's less, get a trickle charger and charge overnight. check again before installing.
  3. Prius Newb
    Prius Newb Junior Member
    26
    Ft Lauderdale, FL
    neg cable attached to car body panel/frame
  4. bisco
    51,798
    just make sure it's a good connection with no paint or rust.
  5. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    When fitting the new battery it is easy-er to undo the negative cable where it is bolted to the bodywork under the rear light. Remove the battery and fit the negative lead to the new battery before putting it in place.
    Make sure the area under the bolt fixing to the bodywork is clean and free of rust. This is a common problem area for bad connections.
    When fitted check the voltage at the front jump point. This should be the same as the battery voltage, hopefully around 12.9/13 volts. When you try to make the car ready do not be surprised if you have to try twice before success. This is quite normal as "dorunron" correctly stated in post (12).
    John (Britprius)
  6. Prius Newb
    26
    Ft Lauderdale, FL
    Oh and FYI...tested the old battery from the jump fuse box connection.. Showing 6v on a digital voltmeter.
    Don't take this the wrong way....
    But I love you guys!!
    #26 Prius Newb, Aug 6, 2014
    Data Daedalus and SageBrush like this.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    My wife disagrees. She thinks I spend way too much time hanging out here.
    Tony D, dorunron and Data Daedalus like this.
  8. Prius Newb
    26
    Ft Lauderdale, FL
    Tell your wife, if I get this fixed with your guys' help, I'll come spend time with her and take her shoe shopping. LOL
  9. JC91006
    16,759
    8,562
    Back in the days when your car wouldn't start, you would check voltage and just go out a buy a new battery. Not sure why it's any different in the Prius. The Prius is still a car you know ;)
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    The short answer is Japanese standard battery posts and reverse orientation. Not a battery you can find at Walmart or even most Auto supply stores.
    OP however is in NJ. One might guess that a Toyota dealership is not too far away, but who knows.
  11. Prius Newb
    26
    Ft Lauderdale, FL
    Update...
    Old battery out of car...measured 7v on meter.
    Waiting on FedEx. tap, tap, tap.
    I'm sure I can find the answer to this question on line or in the forums, but off hand, anyone know if there is a way to determine the age of the YUASA battery I removed? Could really care less how old it is for the purposes of this thread, but hypothetically, if the old battery is only 1 year old and hypothetically, if my replacement battery were to fail after one year, I'd like to be aware that I have a BIGGER problem than just a dead battery.
  12. Britprius
    5,194
    1,921
    There is a date stamp code on the top of the Yuasa battery in the order of DD/MM/YY.
    John (Britprius)
  13. JC91006
    16,759
    8,562
    If the battery says YUASA on it, it's probably original. A replacement from Toyota would say "True Start"
    dorunron likes this.
  14. Prius Newb
    26
    Ft Lauderdale, FL
    So October 15, 2008. Almost 6 years old. What a surprise that the Toyota dealer who sold the car used, to the person from whom I bought it (a good friend, so I know he's not lying to me), told him a little over a year ago, that there was a BRAND NEW battery in it.
    And car salesmen wonder why the average person doesn't trust them.
  15. JC91006
    16,759
    8,562
    If you believe the above comment, then you shouldn't be surprised by the battery being original
    dorunron, SageBrush and Data Daedalus like this.
  16. Prius Newb
    26
    Ft Lauderdale, FL
    So, FedEx deliveryman confirmed I was his last stop of the day. 7:10 pm delivery for the battery. Out of the box it measured 13v. Good so far. 30 minutes later everything is installed except for the carpet and cosmetic pieces. I check the voltage from the fuse box jump hub.... ZERO. Short moment of panic until I realize, in my haste I forgot to connect the negative/ground terminal.
    As soon as I touch the clamp to the post, lights that are supposed to illuminate begin to illuminate, beeps that are supposed to beep start beeping, and things that are supposed to hum begin to hum. I again checked the voltage from the front jump hub and it reads 12.3-12.4.
    Now for the true test; would it start? Started right up and off I went cruising around the neighborhood. Little did I realize how many Prii are in my neighborhood. In my gated community of 85 homes, there are 14 Prii. One house accounting for three all on its own.
    Thank you to all of you for your assistance and patiently answering what surely seem like silly questions. $157 and a little, well ALOT of sweat later...
    YAHOO!!!
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    That is so descriptive of a Prius LOL
  18. JC91006
    16,759
    8,562
    Wow that was lots of typing to say "the new battery fixed everything"
  19. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    A bit like booting up the avionics systems of a Space Shuttle. You don't "start" a Prius....you boot up a Prius and then IT decides whether to start the ICE, after it's bevy of ECUs and sensors have conferred and reached an amicable agreement ;)
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    Yep!
    GrumpyCabbie posted a great line from Llewyn (sp ?) a few days ago along the same vein. He called it 'driving by committee' :)
