Hybrid System or Traction Battery Failure - Japanese Import
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Shirjeel Agha, Aug 3, 2014.
  1. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Check out what they have in Japan
    I cant read, but it looks like you can get either.. and the fact that they sell the adapter seems like the brick could do both 100V and 200V
    Shirjeel Agha likes this.
  2. Shirjeel Agha
    Shirjeel Agha Junior Member
    31
    Lahore, Punjab, Pakistan
    Thank you all for your very valuable inputs. Today I have managed to get the car started through a private workshop where technicians had access to complete Plug-in diagnostics. I was lucky to find them.
    The issue was simple and to me strange as well. The hybrid battery had drained to the extent that when we plugged-in the cable it neither showed the charging status on the display nor the charging indicator lit up. Even the error codes would come back 5-7 seconds of clearing.
    When we had almost given up, we tried setting up the charging timer. When we did that we could see the green charging indicator blinking and if you left the start button on it would switch off after a few seconds. We consulted the owner's manual and found out that these indicated the charge taking place. We therefore decided to leave the cable plugged-in for a while.
    Thankfully after about 2 hours, when we tried again, the error codes cleared and the MID started indicating the charging status of the hybrid battery. This was the point when we pressed the start button and the vehicle moved to Ready Mode.
    What happened with my PIP is neither given in the owner's manual nor in the PIP repair diagnostics. For hybrid system malfunction, the repair manual indicated that hybrid battery may be low and the solution given was to replace the battery pack. I wonder how much I would have ended up spending if we had not hit the clue by chance.
    Yes, the brick can do both. Toyota Japan supplies 200 V cable with the car even though they have 100 V. Mine did not ship with the car but I am getting one soon both from Japan and U.K.
    The jump start process is the same as that of standard Prius. I had tried it a number of times but without success.
    You have correctly understood. There are no Toyota dealers here working with the Plug-ins. They do however support the standard Prius since this has been officially launched by Toyota in Pakistan.
    Just be careful to hook up positive with positive and negative with negative or follow the process given in the manual. The ordeal that I have gone through, I am an expert at it now.
    Since Standard Hybrid is being sold by Toyota dealership here, they also extend all sorts of maintenance support for it.
    Plug-ins are not sold by Toyota dealers but used ones (3 years old max) can be imported from Japan. This is totally legal and one has to pay hefty taxes to the Government for the importation but even after that it costs you less than the Toyota sold brand new Hybrid.
    You are absolutely right in your last part but I loved this car and therefore took the risk. Let us hope I do not repent my decision.
    Please have a maintenance and service section in the PIP Forum. Thanks.
  3. bisco
    52,337
    congrats to you shirjeel, i'm so glad you found some technical expertise. i hope you have a great experience with your new pip! please hang around and join in the conversations, all the best!(y)
  4. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I too am glad to hear you were finally able to solve the problem. Enjoy the car!
  5. Tideland Prius
    16,609
    We will definitely take it into consideration as we try to organise the forum as Toyota adds more Prius models and as there are more generations. Thanks for your input!
    I left a permanent link in the Technical section :)
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I also hope long term you do not regret you decision. I can understand that the "Plug In" Prius isn't being officially sold in Pakistan, but I'm still somewhat surprised that a Toyota dealership would be totally unable or unwilling to offer support.
    Whether it is "officially" available or not...it's still a Toyota product.
    Heaven forbid it was involved in recall.
    Sincerely, best of luck with your ownership. Glad this problem was relatively easy to solve.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Op, let's see some pictures of your new (and newly fixed) ride.
  8. Shirjeel Agha
    31
    Thanks a million Bisco. I appreciate your support.
    Thanks a lot. I am a happy Prius owner now.:D
    Thanks for your good wishes.
    Toyota dealership here has limited expertise in PIP therefore they are usually reluctant to repair major faults. For oil change etc one can always go to them.
    srzbae and GrumpyCabbie like this.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Great! Glad it is Fixed!!!(y)
    Enjoy your car.:D
  10. Shirjeel Agha
    31
    A bundle of thanks.
    Here are few stock pictures. Will post fresh in due course. Not sure if these would take a lot of space on the thread.
    #30 Shirjeel Agha, Aug 7, 2014
    m.wynn, retired4999, drash and 2 others like this.
  11. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    You're making me jealous now :)
  12. bisco
    52,337
    beautiful, but i think you flipped the negative, the steering wheel's on the wrong side!:X3:
  13. CharlesH
    2,797
    1,164
    Roseville, CA
    Just in case someone doesn't "get it", the point is that Japan drives on the left, like the UK and many Commonwealth countries, so the steering wheel is on the right. :)
  14. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I believe he was joking :rolleyes:
    But you're right, our steering wheel is on the correct side, the 'right' side. And to go over an old and frequently discussed subject, left hand driving is inherently safer as more people are right eye dominant and a quick glance at my drivers mirror is probably more likely to go in quickly compared to a right eye dominant person in a LHD car using their left eye.
    http://www.wheels.ca/switch-to-driving-on-left-from-right-makes-sense/
    -Rozi- and Shirjeel Agha like this.
  15. Shirjeel Agha
    31
    It is Right Hand Drive in Japan and Pakistan like in UK. I leave the debate of better driving system between Americans and the Brits :) :sneaky:
    #35 Shirjeel Agha, Aug 7, 2014
    GrumpyCabbie likes this.
  16. Former Member 68813
    3,524
    983
    US
    Congrats on fixing this. Are Prius cars popular at all? What cars are popular in Pakistan? Is it a corolla country like Afganistan?
  17. Shirjeel Agha
    31
    Thanks.
    Well I would say it used to be a Corolla country but a major share of the local market has also been captured by Honda for the last decade or two. Toyota, Honda and Suzuki are the leading car makers and popular in the same order of priority. We mostly have smaller cars with engine capacity between 800 to 1300 cc. With better fuel economy cars, however, this trend is changing and we now have a sizable market for 1600-1800 cc cars.
    With import of used cars from Japan and UK now allowed, we have all sorts of models mainly from Toyota and Honda plying on Pakistani roads. Prius is becoming a popular ride in major cities but remains limited to conventional hybrid only. Toyota is officially selling a variant of UK's T-4 with reduced options to keep the price tag relatively low. However, it is still exorbitant forcing people to go for various used Japanese trims/ grades like S, S Touring, G, G Touring and G Touring Leather Edition. These Japanese trims are not only cheaper but also carry many additional features that are not available in officially sold Toyota Prius.
  18. bisco
    52,337
    you got the best color too, and i love the PHV on the hatch, i wish mine had that!(y)
  19. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Totally agree about the coloUr, since mine is the same... I'm too much of a reserved Brit to like the big PHV!
    Shirjeel, once you've got to grips with the car, I'd love to hear how it operates in the different modes - what speed it drops out of EV to HV, whether you can reproduce EV-BOOST etc. I'm gradually getting a handle on the UK/US model differences, but would be really interested to hear about the Japanese model.
    As a first question, you will have three buttons in a line on the console. One will be ECO, the middle one EV/HV, but what does the last one say? PWR, EV CITY, or something else? Assuming it's not a Japanese character...
  20. bisco
    52,337
    if you've got it, flaunt it!(y)
