Losing power randomly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brandon99, Aug 7, 2014.
  1. Brandon99
    Brandon99 New Member
    Oran mo
    Okay so when I was driving through town yesterday I just lost power, the main light came on steady with the vsc and brake light. So I turned it off and turned it back on the drive until 4 minutes later it did the same thing. Well I noticed my headlight was out. I tapped it and it came back on. Turned the car off and back on and no check engine light or anything. 10 mins later it happened again. What's the problem?
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Gonna need to have it scanned for codes but the most likely cause is a fault with the 12 V battery system.
    If the battery is going dead or the battery cables are loose, it can cause a whole host of strange symptoms and set random, unrelated codes.
    Get the battery checked; or if it is the original OEM (5 years old) you might as well just shop for a new one.
  3. Brandon99
    Oran mo
    Code was c1241
    There aren't any signs of the battery going dead though. Lights aren't dimming or anything
    #3 Brandon99, Aug 8, 2014
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    You may have an inverter coolant pump problem but the code does indicate loss of 12V power.
  5. Easy Rider 2
    1,584
    258
    Ocala, FL
    Like anything else electrical, the battery can be intermittent too.
    And it is hard to see brightness variations of the lights in the daytime.
    Not saying that it HAS to be a 12 V battery problem but the experience of a LOT of owners suggests that it very well could be and dismissing that without getting it tested could be a big mistake.
    The really unfortunate part is that the battery can test good one minute and fail a few minutes later.
  6. Brandon99
    Oran mo
    I pulled the test screen up on the touch panel and the battery reads 10.2 volts on accessory mode but 13,6 volts when turned on
  7. bisco
    51,840
    disconnect the battery and measure it at the posts with a voltmeter after the surface charge is gone.
  8. Easy Rider 2
    1,584
    258
    Ocala, FL
    Both readings are somewhat low.
    10.2 is WAY low and the charging voltage when ON should be a bit more than that too probably.
    I think you are on the verge of total battery failure.
  9. Patrick Wong
    18,200
    6,500
    Replace the 12V battery now.
  10. Brandon99
    Oran mo
    Will this cause my left headlight to go off? When the headlight bulb works, the car runs fine.
  11. Patrick Wong
    18,200
    6,500
    What kind of headlights does your car have?
    If HID, replace the bulb now because it is getting marginal and not staying lit given the high voltage applied to it by the ballast.
    A failed headlight is not going to cause your car to stall. So you need to consider that your car has multiple issues.
  12. Brandon99
    Oran mo
    I don't think it has HID. The bulb works. It just randomly goes out. If you tap the headlight it comes back on eventually and the car runs fine
    No fog lights so I don't have HID
    #12 Brandon99, Aug 9, 2014
  13. bisco
    51,840
    do you have any aftermarket accessories like remote start?
  14. Brandon99
    Oran mo
  15. Easy Rider 2
    1,584
    258
    Ocala, FL
    What does "eventually" mean ??
    And you might have the cause and effect backwards; that is, when the car runs fine, the headlight works too.
    I still think that you simply need a new, fully charged battery but when you "tap" on something and it starts working again you have to consider a loose connection somewhere.
  16. Brandon99
    Oran mo
    Eventually means it doesn't come on when I hit it once or twice but as I keep hitting it, it "eventually" comes back on. And I will check on the battery when I take it to the dealer on Tuesday.
