Buying v (lowercase v) Five: Should I have dealer change to 15" wheels?
Discussion in 'Prius v Main Forum' started by pineapplehead, Aug 8, 2014.
  1. pineapplehead
    pineapplehead New Member
    Dallas, TX
    Hi all,
    I'm about to purchase my first-ever Prius, a used 2012 v Five (mainly for the heated seats and leather). I've been able to do a lot of research thanks to this forum. So thanks for being such a great community!
    I'd like to pose a question for you all:
    Should I have the dealer change the 17" wheels to 15" or 16" as part of the negotiations? I am not very concerned about looks. I have a daily 45-mile round trip commute that includes about 25 miles on a highway in poor condition and I want my ride to be as quiet and comfortable as possible.
    I know that I could just take it as-is with the 17" wheels, and change them later if I think the road noise and ride quality is bad after driving it a while, but that would probably cost me a few hundred dollars and I'd have extra tires and wheels to have to try to sell on my own.
    So if your main concerns were noise and comfort, would you switch out the 17s for 15s or 16s? And is it stupid to "downgrade" in this way right off the bat before owning the car for a few weeks/months and then deciding?
    Thanks for your input!
  2. mikefocke
    4,038
    1,832
    Sanford, NC
    The 16"s were the base option on the v when I bought. You keep them pumped up beyond the Toyota recommendation if you want good mileage so they are going to be harsher than what you are used to.
    You can get leather (well really Softex) installed on a v3, I did at sale and it was done with a kit from Southeastern Toyota Distributors with a Toyota part number.
    I'd get the 17"s and offer a straight up trade on Craigslist for someone who just has to have the lower profile tires that the 17"s use. I wouldn't want the 17"s but that doesn't mean someone else wouldn't as there are many looking for the look.
    BTW, the 16" wheels are nice without the wheel covers and just a cheap plastic cap. Look almost "alloy"..
    pineapplehead likes this.
  3. rjparker
    10,415
    6,522
    You are probably right that the ride might be better with 15" but I think it would be more noticeable at lower speeds on poor roads. You will have speedometer calibration issues also, but perhaps the dealer can adjust for the smaller size.
  4. Mendel Leisk
    41,829
    My rule of thumb is to try to keep things stock as much as possible. Put yourself in shoes of potential buyer down the road, which would be preferable to them? YMMV ;)
  5. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I agree 100%. If the ride and noise level was so bad with 17" wheels and tires, WHY does Toyota put them on the top models? Why would 16" wheels be that much better? In my opinion, the negative rap on 17" wheels and tires is over blown and perpetuated by those that have NO actual experience. I have a 2012 Prius Plug In that came with stock 15" wheels and tires. Within the first week, I purchased a used set of the Prius 5, 17" five spoke wheels and tires. I run 40 psi front and 38 psi rear. My ride is neither uncomfortable, harsh, "bone jarring", etc., as I've read here. Noise, what noise? It just isn't so. OP, keep the factory 17" wheels on the Prius v Five and enjoy the look and ride.
    pineapplehead and ems2158 like this.
  6. Mike500
    Mike500 Senior Member
    2,593
    767
    17 inch wheels are a "looks over substance" choice.
    Changing to smaller wheels might likely reduce residual resale value.
    If you intend to keep the car for a long time, do what you desire. It's YOUR car.
  7. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    The 16" wheels and Blizzak tires we use in winter have a more pleasant ride than the original 17" wheels and tires we use the other three seasons but the difference is not huge. If you keep the 17" wheels and tires, do not over inflate them - keep them at the pressures shown on the door jam which I think are 33 psi front and 32 psi back.
    If you are interested in getting maximum fuel economy then don't buy a Prius v -- buy a regular Prius or a Prius c.
    If the Prius v you are looking at has the Advanced Technology Package then it has Adaptive Radar Cruise Cruise Control which can make a long commute easier. You can tell if it has the "ATP" package by the silver following distance adjustment button with an image of a car on the right side of the steering wheel.
  8. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    I have a 2013 Prius v Five. The wheels are the 17" that are standard on the car. I have driven 18,000 miles and have no issues with the ride or noise from these wheels I would not consider trading them for 16s. What would concern me with the downgrade would be losing some stability at high speed. I've found the Prius v to be very stable at speed and is not tossed around by high winds and passing trucks. I haven't driven a Prius v with the 16" wheels but I suspect there would be less stability at speed.
    The roads in PA were in terrible condition after last winter. The Prius v survived without tire or wheel damage.
  9. MSA14
    MSA14 Junior Member
    74
    Metro Atlanta, GA
    I would keep the wheels and purchase a spare set of 15's.
    The 15's can be had for cheap.
  10. Mendel Leisk
    41,829
    This is our first Prius. We initially took a test drive with (equiv. to) Level 4 model, with 15" wheels. To be fair, it was dark, we were very unfamiliar with the car, but it didn't feel like a good fit.
    Then we went back, wandered around the lot, and found this Touring model (similar to US level 5, with the 17" OEM wheels). It was sort of buried at the back, in this undercover display room. It was dusty, with a dead bird beside it, lol.
    They dug it out for us, we went for a (daylight) drive. I do not know if it was just getting more used to the Prius or what, but I felt completely at ease in that car. It had the Michelin Pilot tires, felt like hand-in-glove.
    FWIW, when I put 195/65R15 Michelin X-Ice on it every winter, it still feels good ;)
  11. pineapplehead
    Dallas, TX
    Thanks for all the responses! I think I'll keep the stock 17s, and if the noise/ride bothers me, get a set of 15s while keeping the 17s for resale.
    Still trying to find "the" car to buy, so I still don't know how it's going to feel to me once I drive it for a while.
  12. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    If I was buying a used five knowing that it came with 17's but the car has 15's, I would tell the seller to deduct the cost of the OEM 17's rims and tires from the cost of the asking price. It's about $2000. If I was you, I'd keep the 17's in the garage and buy a set of used 15's
  13. pineapplehead
    Dallas, TX
    Update: I brought home my new car last night!
    2012 Prius v with Advanced Technology Package in Blizzard Pearl with bisque interior.
    It was very hard to find this car (v 5 ATP, in any color) used. At first I was going to either fly 800-1000 miles away and drive one home, but as I did the math on that and factored in the inconvenience, plus my husband's resistance to the cost and hassle, I decided I'd settle on a white v 5 with no ATP. So for the past 3 weeks I had been checking online inventory at all the dealers in my area for the right combination. It was a frustrating process trying to work with dealers whose online inventory did not match up to what they actually had available. I was almost ready to give up and buy a different color because we really needed the new car.
    On Monday night I was about to buy a 5 model without ATP in a color I didn't want just because that was what was available, the price was good, and I'd been spending way too much time shopping and agonizing over it. When we got to the dealer, they said the car had already been sold.
    Then on Tuesday morning during my routine online checks, a white v 5 with ATP magically appeared at my local CarMax. I think it was a sign :)
    I love it so far and I believe I made the right decision! (It was hard to decide after I'd already gotten used to the idea of spending a few grand less on a v 5 with no ATP whether it was worth another few grand for the ATP.) At first I just wanted the ATP for the double moon roof and sound system, but when I read about people's experiences with the safety features and DRCC it seemed like it could possibly save my life - so that definitely justified the extra cost to me. Like someone here said before: it's like paying extra for airbags a decade or two ago - a no brainer. (Plus getting moon roofs and a premium sound system thrown in!)
    If anyone's interested: based on my online research (which may or may not accurately reflect true inventory), dealers in the Dallas area were charging $21-24k (minus whatever I would be able to haggle) for used 2012 Prius v 5 models with no ATP. I bought my 2012 v 5 with APT at CarMax for $26,000 (no haggling allowed). This is for the July-August 2014 time period.
    So, case closed for me. I'll need to spend several hours learning how to use all the fancy features. And I'm keeping the 17" wheels for now unless they really start to bug me later.
    YAY!!!
  14. Offline
    646
    240
    Lenexa, Kansas
    It sounds like you bought the same 2012 Blizzard Pearl Prius v with ATP that we have. One of the "fun" features that we never use is that it can parallel park itself or back into a straight-in parking place. We don't use it because we almost never park that way but it is fun to watch.
    IMO, the adaptive cruise control is the primo feature. People who have this feature tend to use it most of the time according to an Insurance Institute study: http://www.iihs.org/lifesavers/pdfs/Toyota.pdf
    Once I experienced DRCC in our Prius v, I couldn't tolerate buying another vehicle without it - hence our recent purchase of a Sienna that also has it. DRCC made our 1,000 mile July 4th weekend drive on packed Interstate highways wonderfully restful. Nobody was going to get to their destination faster than anybody else so I just set DRCC on the maximum following distance, put on some music and enjoyed myself.
    The Pandora interface is my favorite part of the nav/audio system - cool to see the album covers on the nav screen. Register your Prius on the Toyota Entune website ASAP to use all the features. If you don't have a smart phone, get one so you can use all the features.
    Press the SOS button in the "ceiling" to see if someone answers. If your Prius doesn't have an active "SOS" account, ask for a reduced price. It's still a lot of money for the service you get but it could come in handy if you crash your Prius or if it is stolen.
    Try the Bing search. If a business you are looking for is too new to be in the navigation database, you can often find it with Bing and send its location to the navigation system.
    Just figuring out the features are going to keep you busy for a long time - way more than "several hours".
