New 2004 purchase with the triangle light due to....
Discussion in 'Gen 2 Prius Technical Discussion' started by Priusdoctors, Jun 10, 2014.
  1. Priusdoctors
    Priusdoctors New Member
    Seattle
    A bad coolant flow control valve sensor. And a sensor on the coolant canister. Also it was in a front end wreck. I push the power button once and everything turns on including the radiator fans and the engine. It seems that when I'm driving that the engine doesn't turn off when I'm at a stop light also. And another thing that I'm noticing when driving that the brakes don't have that harder brake engagement when almost coming to a stop. It's also weird that everything turns on with one push of the power button.
    #1 Priusdoctors, Jun 10, 2014
  2. Priusdoctors
    Seattle
    The power button instead the 2.
  3. Priusdoctors
    Seattle
    Problem solved.
  4. bisco
    51,895
    your welcome!(y)
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  6. bisco
    51,895
    doctor, heal thyself.
    dorunron likes this.
  7. dorunron
    3,318
    1,105
    Houston, TX
    Mind over matter.
