Toyota why is the mpg readout not accurate?????
Discussion in 'Gen 3 Prius Fuel Economy' started by alfon, Aug 11, 2014.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Its seems like now for over 5 years, we purchased our 2010 Prius in May, 2009, that Toyota would
    software repair the mpg readout which is always off, over reading, by 2.5 to 4 mpg's.
    I had access to a 2006 Honda Civic Hybrid which always read 1-2 mpg under of what the computer reported. I would much rather see our Prius under read than over read and give us optimistic false readings.
    The Prius over reading on mpg is not a one car example; all the Prius v, Prius Plug in, Prius liftback, and Prius c, all have this reported issue.
    Toyota should be required to address this issue in the new redesigned Prius for 2015 or 2016, or whatever year Toyota decides to release it....
  2. fuzzy1
    10,406
    Through what mechanism do you propose?
  3. Okinawa
    Okinawa Senior Member
    1,333
    320
    I have a 2014 Avalon Hybrid XLE Touring. Same for it as well. Sometimes it is close, sometimes it is not. Probably depends on how full you get the tank I would think.
  4. bisco
    51,840
    i think some honda drivers beg to differ.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Beg to differ with WHAT exactly ??
    It would be MUCH better if you would quote the comment that you are replying to.
    I have a Ford Fusion. It's numbers are a bit high too.
    I occasionally visit the Volt forum too. Same reports there.
    Same thing with my ICE only Malibu and Elantra.
    To the OP: Get used to it.
    Do you think the manufacturers would purposely cause the display to read LESS than the actual mileage ??
    It is an estimate and ONLY an estimate.
    mtbiker53 likes this.
  6. bisco
    51,840
    that's what i'm saying, he said his honda under reported.
  7. Mendel Leisk
    41,313
    Our second gen Civic hybrid always slightly underestimated mileage. One good thing I can say about it...
    Yeah it would be nice if Toyo would 'fess up. Ours is roughly 8% optimistic.
  8. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    If you realize the mpg reads high and you have checked for a number tanks of gas... the problem is solved. You are now calibrated and can read the mpg knowing it is 5% or so high. Use your valuable time to worry about something else :)
  9. ETC(SS)
    7,134
    I've never had any problem..... ;)
    SageBrush likes this.
  10. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    It is just a guideline. Whether it reads over or under, you want to maximize it. The exact mpg is only good for bragging rights. It is probably not possible to get it much closer. The temperature of the gasoline would have to be taken into account (both going in and coming out) , as would your elevation, air temperature and the mechanical condition of your car. I suppose if you were willing to pay a few thousand more the car, Toyota could make the mpg a bit more accurate. 5% seems pretty good, considering....
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    On my list of concerns this ranks very low.
    I can subtract.
    And actually, I find my readings to be fairly accurate.
  12. mcmmotorsports
    mcmmotorsports Junior Member
    37
    Greensboro, North Carolina
    I would like to see them correct this as well. I accept the fact that 50mpg=48MPG in the real world but a simple software fix would give me warm fuzzies.
  13. CaliforniaBear
    1,180
    289
    Northern California
    Simple software fix = Oxymoron
  14. mcmmotorsports
    37
  15. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    It would be nice if the MPG was more accurate, but I also agree that it is a relatively minor annoyance. From what I can tell the more important things like speed and distance traveled seem to be almost right on. This is compared to my wife's old Honda Odyssey where the speedo and odometer are both about 10% off.:mad:
  16. CaliforniaBear
    1,180
    289
    Northern California
    My speedometer reads 2 mph high at 60 mph. While this is pretty typical my 2004 Highlander exactly matched the GPS speed.
  17. Mendel Leisk
    41,313
    You're in denial, no offence.
  18. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    We have this same conversation on the UK Prius forums - a lot.
    The way I explain it is this. Take a set of scales, one from your kitchen and one from a laboratory. But one costs $10 and one costs $10,000. How can that be as they're both scales? One measures to within +/-5% and the other measures to within 0.0000005%.
    Same with the Prius fuel consumption computer. They could make it 0.5% accurate but it'd cost $100. I'll stick with the 5% accurate one for $2.
    Simple.
  19. Mendel Leisk
    41,313
    ^ I'd agree this a well flogged dead horse. But anyway... ;)
    I've been logging mpg for around 45000 km. I also note what the car tells me. It's never remotely close. The average error is around 8%. The least is around 6%, the worst near 10%. That's not due to limits of accuracy, that's an intentional spin on Toyota's part.
    Sure you can take it with a grain of salt. Just like when you contend with any perennial BS'r.
    #19 Mendel Leisk, Aug 11, 2014
  20. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    FWIW, the MID milage numbers for our 2014 Prius-4 seem to be rather consistently 5% optimistic:
    • 50.8(MID)/48.5(tank) = 1.05
    • 51.7(MID)/49.4(tank) = 1.05
    • 50.0(MID)/47.9(tank) = 1.04
    • 47.0(MID)/44.6(tank) = 1.05
    • 50.6(MID)/48.4(tank) = 1.05
    • 46.2(MID)/43.4(tank) = 1.06
    • 47.8(MID)/45.4(tank) = 1.05
    • 47.5(MID)/45.2(tank) = 1.05
    and when I sum all the MID numbers and all the tank numbers, and divide the results, I get an *average* MID/tank ratio of 1.050.
    #20 70AARCUDA, Aug 11, 2014
    szgabor likes this.
