XM Satallite
Discussion in 'Gen 2 Prius Main Forum' started by cellotim1974, Mar 23, 2006.
  1. cellotim1974
    cellotim1974 New Member
    I had my XM MiFi installed at Best Buy. I have it plugged into the AUX jack (2006 Prius).
    At first they used a standard, generic "mini" to "mini" cord to hook up th device. It worked, but there was a terrible hum in the background. They swapped out the cale and replaced it with expensive Monster cable "mini" to "mini". The overall qual;ity of sound is great, but there is still the annoying hum. Anybody had this problem?
    Is it a grounding issue, do I nedd some kind of noise filter...HELP? I love XM Radio!!!
  2. jsf
    jsf Member
    155
    Anytown
    Go to Audio and Electronics Forum and search. Has been discussed.
  3. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    The noise is coming from the power adapter. Unplug from the AUX jack and the noise will go completely away. I had the same problem, but I solved it by installing Coastal's XM radio kit into the car and selling the MiFi. Hopefully, someone else has solved the problem.
    ---Kent
