Code P0AFC on non-mobile PiP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by DadofHedgehog, Aug 20, 2014.
  1. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    Folks, the 2012 PiP just refused to activate yesterday and threw a code "P0AFC", which mystified the local Toyota dealer. The 12V battery (2 month old Optima Yellow Top) completely completely discharged overnight. Jump-starting did nothing. Jump-starting along with the Toyota fob "T-to-Power Button" procedure did start the car, with the following two alternating messages on the dash display: "CHECK HYBRID SYSTEM STOP THE VEHICLE IN A SAFE PLACE" and "P LOCK MALFUNCTION WHEN PARKING, PARK IN FLAT PLACE AND APPLY PARKING BRAKE SECURELY". ToyotaCare sent a free tow to closest dealer, Toyota of Louisville, who is mystified and will keep the car for a few days. Internet shows two P0AFC codes for a 2010 Prius (P0AFC-129 and P0AFC-150), both related to the hybrid system (inverter, etc).
    Search of PriusChat so far shows nothing on this code. Anyone out there in PIPland see this before? Thanks in advance.
  2. CharlesH
    2,797
    1,165
    Roseville, CA
    The dealer needs to get on the phone with Toyota's dealer advanced support group. The only consolation here is that this is clearly an issue covered by the warranty. In fact, Toyota probably really will want to get the bottom of something like this as a quality issue.
  3. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Doesn't look like an inverter issue...
  4. DadofHedgehog
    681
    282
    northern Virginia
    Yes that's the Gen III 2010 codes pdf I found - I was writing from memory. Not an inverter issue.
    I'm surprised at the relative uniqueness of my fault code's (non)appearance here on PriusChat. Not a good way to be a pioneer...
  5. bisco
    52,402
    why are you on a replacement battery?
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Very good question Bisco.
    The next question: the chicken or the egg ?
    #6 SageBrush, Aug 20, 2014
  7. bisco
    52,402
    chicken. edit: make that two chickens.
  8. DadofHedgehog
    681
    282
    northern Virginia
    I bought an Optima battery in July because the OEM battery gave out in July.
    More new facts: Toyota dealer reports that the Prius has a constant parasitic draw of 1.4 Volts now.
  9. CharlesH
    2,797
    1,165
    Roseville, CA
    That doesn't make any sense. Parasitic draws are measured in Amps, not Volts. (If this was a satirical comment, sorry I missed it.)
  10. bisco
    52,402
    sounds like whatever killed the oem, has done the same to the optima. i think they were having this trouble in europe.
  11. DadofHedgehog
    681
    282
    northern Virginia
    Well, mystery solved. The "parasitic 1.4V draw" (via phone) turned out to be a constant 1.4 amp draw. I just spoke to the tech in person after a family vacation. The draw was caused by a faulty wiring connection while installing the JDM folding mirrors.
    Tracksyde likes this.
  12. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Is the dealer going to charge you for the diagnosis and repair?
  13. DadofHedgehog
    681
    282
    northern Virginia
    Oui. But... not so much.
  14. RRxing
    2,554
    1,828
    NEPA
    Who installed the mirrors - you, the dealer, or some 3rd party?
  15. bisco
    52,402
    that's the problem with some of these issues, you never get the whole story when trying to diagnose.
  16. mrbigh
    3,686
    699
    Long Island, NY
  17. DadofHedgehog
    681
    282
    northern Virginia
    I installed the mirrors. I bought the Taiwan mod kit used from another member here. It's early yet, but based on some symptoms I suspect the li'l used circuit box that came with the Taiwan kit. I made all the wiring connections myself and checked them several times since installation, so...
  18. bisco
    52,402
    that wouldn't surprise me. careful installation usually leaves only product problems as the culprit.
