Prius 12 volt charging current
Discussion in 'Gen 3 Prius Technical Discussion' started by AHetaFan, Aug 24, 2014.
  1. AHetaFan
    AHetaFan Member
    104
    55
    I had the factory battery go dead while I was away traveling for 3 weeks 7 months after I bought the car. 6 months later I was gone 2 weeks and it was dead. I hadn't realized I needed to buy a charger and park within reach of a plug not having had a problem with previous cars. This caused me to spend time reading about the Prius 12v system and learning that the don't charge over 5 amp label on the battery is ignored by Toyota. The car is more than happy to supply as much charging current at about 14.4 volts as the battery will draw. It relies on the vent tube to keep gases out of the car. The battery is sealed so you can't add water. My 12v battery drained flat twice is already damaged as evidenced in reduced EV mode range. I also intend to camp in my Prius like it is an RV and run a 12 volt refrigerator. The factory battery is woefully inadequate for running a refrigerator for long periods of time without running the car. For both reasons I need more battery capacity and deep discharge design. I have replaced the 45 AH factory battery which came in my 2012 Plug-in Prius with a larger group 25 automotive lithium 12 volt battery (I will also be adding another battery in parallel and 300 watts of solar panels when camping with refrigerator).
    I wanted to see what the charging behavior would be compared with what is documented elsewhere on there boards for lead acid batteries in earlier Prius models.
    I used an old Heathkit Automotive meter which has a 90 amp shunt for measuring charge current. I rigged the shunt in the positive cable at the battery. I also used a DC current clamp on meter which I clamped over the negative battery cable. To test the setup I created about a 15 amp load and compared the two with a digital meter which has an internal 20 amp shunt good for measuring current for 15 seconds. All 3 where pretty close at 15 amps current draw.
    I discharged the battery about 60%-70% and powered on the car.
    Initial charge current measured on the shunt as soon as I got around to the back to read the Heathkit automotive meter. Result 60 amps. Clamp on meter 70 amps
    After 5 minutes automotive shunt 47 Amps. Clamp on meter 60 amps
    After 10 minutes automotive shunt 45 Amps. Clamp on meter 58 amps
    After 15 minutes automotive shunt 44 Amps. Clamp on meter 57 amps
    After 20 minutes automotive shunt 43 Amps. Clamp on meter 56 amps
    After 25 minutes automotive shunt 43 Amps. Clamp on meter 55 amps
    After 30 minutes automotive shunt 41 Amps. Clamp on meter 53 amps
    After 35 minutes automotive shunt 41 Amps. Clamp on meter 52 amps
    After 40 minutes automotive shunt 40 Amps. Clamp on meter 51 amps
    After 45 minutes automotive shunt 37 Amps. Clamp on meter 49 amps
    After 50 minutes automotive shunt 36 Amps. Clamp on meter 46 amps
    After 55 minutes automotive shunt 27 Amps. Clamp on meter 36 amps
    After 60 minutes automotive shunt 1 Amps. Clamp on meter 1.3 amps
    After 65 minutes automotive shunt 0 Amps. Clamp on meter 0.1 amps
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    What's the amp hour rating on your Group 25 battery?
  3. bisco
    51,154
    hold on, a poor 12 volt is reducing your ev range?
  4. AHetaFan
    AHetaFan Member
    104
    55
    64 AH
  5. AHetaFan
    AHetaFan Member
    104
    55
    Yeah. I have the Plug- in Prius and should see at least 12 miles EV only range indicated on the dash on a full charge. Been a long time since I saw that. 9-10 is all I have seen for a long time. The EV traction battery charges the 12 volt battery via DC to DC converter. The poor state of the lead acid battery caused it to draw more charging current than normal. That power is diverted from EV use to battery charging. I gained 2 miles of EV range as indicated on the dash display by replacing the 12 volt battery.
    LeeD and j12piprius like this.
  6. fuzzy1
    10,335
    Nothing unique about Prius here. This is generally true in all passenger cars, even traditional non-hybrids with regular size batteries.
    Battery drain from those 12V refrigerators is one of the reasons that most 12V outlets are now disabled when cars are shut off.
  7. AHetaFan
    AHetaFan Member
    104
    55
    I agree. I didn't intend to imply otherwise. Just explaining my reasons for my battery choice.
  8. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I sure hope so! 5 amps at 12 to 14.4 V is 60 to 72 Watt. Your headlights are 55W each. That would mean that only turning on the headlights would mean your battery would slowly discharge. Not mention the rest of the power your car needs: radio, fan, dashboard, sparkplugs!
    I have never seen a " don't charge over 5 amp" label on a car battery, and every car will charge your battery at a higher current, if needed.
  9. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    , I suspect that is for an unregulated dumb charger that does not control voltage. Even Optima battery shops will tell you to hit a very dead and long neglected Optima that does not want to accept a charge, with up to 100 amps for up to an hour to shock it back into accepting a charge. As long as the battery does not overheat or is hit with too much voltage which forces too many amps into a nearly charged battery and causes the relief valves to open and vent electrolyte, it will not damage the battery.
    My Optima red tops and Exide Orbital starting batteries often charge in excess of 60 amps for a few minutes or more. They are still functioning fine after 15-20 years of that in spite of having that little sticker that warns about exceeding a few amps. It seems as long as the charging system is properly voltage regulated, no harm will come to the battery.
    j12piprius likes this.
  10. AHetaFan
    AHetaFan Member
    104
    55
    There is a lot of cleaver engineering in the car. I assumed based on the label on the battery that they might be limiting the charging current delivered to the battery while the DC to DC converter supplies all of the cars 12v current needs once the car is powered on. I believe the DC to DC converter can supply 125 amps based on the label where if feeds into the main fuse block under the hood. The Prius battery is unique in dimensions, vent tube, pencil posts and this label to limit charging current. Why? Few manufacturers make a direct replacement battery. Toyota, Optima and Exide are the only ones I know of. There are many posts on this board mentioning the low charge current specified on the label of the factory supplied battery. It is actually the manual that says 5 amp. The battery says charge at no more than 4.2 amp as seen in the attached pic of the factory supplied battery that came in my car. Apparently Toyota thinks that people will go buy a low current charger and use it rather than the car to charge the battery before they drive the car if it gets heavy discharged. As long as it stays nearly charged from regular use the car won't charge it at too high a current and most people will get excellent long battery life. Parked at the airport far from a plug for 2 or 3 weeks falls outside of their parameters. If you have to jump it and drive home its going to be charged at over 10 times the labeled rate on the battery while you drive. They keep you safe by venting all the gassing to the outside.
    Paullllc likes this.
  11. bisco
    51,154
    it all depends on the health of the battery when you long term park it, and there is no easy way to know that. i've parked mine for 5 weeks, two years in a row in an unheated garage that does not drop below freezing. same with my '04 and '08, unto six weeks.
  12. Former Member 68813
    3,524
    983
    US
    Sorry, but this is not how the lead batteries work. If they are discharged, they can accept huge charge currents without gassing. Gassing only happens when battery is full and still charged at 14.5V and above. The sealed batteries have ability to recombine the H2 and O2 gasses back to water, but 4A is probably the recombination limit and battery will start venting outside when still charged while full.
    So, your little theory about charging at 10x the limit is all wrong.
    If you leave the car off for a long time, disconnect the battery leads and use solar charger.
  13. AHetaFan
    AHetaFan Member
    104
    55
    Then there is what it says in the owners manual about jump starting and charging to consider. Perhaps the truth lies somewhere in between. No matter. All I intended to do is share the actual charging behavior of the car for those interested and those considering replacing their batteries with indirect replacements.
    Prius Rising likes this.
  14. Maarten28
    415
    224
    Netherlands
    What does it say in the US owners manual about jump starting? In the Dutch manual it just says to connect a second car's battery to the auxilliary start connector in the fusebox in the engine bay and then to wait 5 minutes while the second car charges the battery.
  15. AHetaFan
    AHetaFan Member
    104
    55
    There are bits about the 12V battery in several place in the manual. Page 472 Warning about it producing hydrogen gas. Disconnect the negative cable before charging the battery while in the vehicle. Page 474"How to charge the battery" " Only perform a slow charge (5 A or less). The 12 Volt battery may explode if charged at a quicker rate" So why does the car charge a 8 - 10 times that rate if it may explode? Glad I don't have that charge rate sensitive explosive battery in the car any more. Page 594 - 596 covers jump starting pretty much as you boiled it down except the donor car is supposed to be running at elevated engine speed for that 5 min before you try to start the Prius. It also states that once vehicle is started to have the vehicle inspected at a Toyota dealer as soon as possible. Maybe I should have the Dealer inspect the charge rate. Maybe the high charge rate I see is a malfunction though I tend to doubt it.
  16. Former Member 68813
    3,524
    983
    US
    I see that I wasted my time trying to explain. Oh well...
  17. AHetaFan
    AHetaFan Member
    104
    55
    I don't believe you have addressed Toyota asserting in the owners manual Page 474"How to charge the battery" " Only perform a slow charge (5 A or less). The 12 Volt battery may explode if charged at a quicker rate" And the label on the battery itself "never charge quickly" specifying 4.2 amps. I don't see a difference between the car charging at a higher rate than this or using a separate battery charger and charging at a higher rate. Your calling my actual measurements of the cars charging current a "little theory" is uncalled for.
  18. Former Member 68813
    3,524
    983
    US
    I'll try one more time (the last time).
    The car can charge at high rate because the car has a smart charging system that will never overcharge and produce out-gassing.
    The label assumes the worst case scenario, ie the owners using dumb chargers causing overcharging and out-gassing, and the 5A limit is to prevent overcoming the catalytic gas recombination and venting flammable gasses and/or increased pressure in the battery. This is for legal purposes.
    There are lots of resources online explaining how lead batteries work.
    You Patriots likes this.
  19. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
  20. JClay
    JClay New Member
