Which hybrids had the smallest engine?
Discussion in 'Toyota Hybrids and EVs' started by Troy Heagy, Aug 25, 2014.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    Let me know if I left any out:
    1.0 1999-2006 Insight
    1.3 2002-2009 Civic and 2010-14 Insight
    1.4 Chevrolet Volt
    1.4 Jetta Turbo
    1.5 1998-2009 Prius + the C
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    What are you getting at? The Prius has a 1.8 which whilst small for the US market, is regarded as quite large over here. But if I recall, it works in a way where it gives optimum efficiency.
    Large(r) cars have often had much smaller cars here. The Jetta with a 1.4 is adequate but the much larger Skoda Superb has had a 1.4 litre engine for quite some time. Imagine a car this size with such an engine and has similar performance to the Prius. Dead easy to imagine with petrol costing over $8 a gallon. (the car is also much cheaper to buy than a Prius)
  3. Troy Heagy
    Troy Heagy Member
    1,218
    Nothing.
    I was watching a review of the Jetta Turbohybrid and was surpised to hear it's only 1.4 liter. So I was just curious what the smallest engines were in hybrid cars (since I am an engineer and find this stuff fascinating).
  4. Mendel Leisk
    41,117
    Yeah, with our 2nd gen Civic Hybrid, it was kinda cool: 1.3 liter 4 cylinder, with 8 spark plugs.
  5. Trollbait
    12,461
    "Dual ignition promotes engine efficiency by initiating twin flame fronts, giving faster and more complete burning and thereby increasing power.[6] Although a dual ignition system is a very effective method of achieving optimum combustion and better fuel consumption, it remains rare in cars and motorcycles because of difficulties in siting the second plug. Alfa Romeo Twin Spark cars (eponymously) use dual ignition, as do Honda cars with the i-DSI series engines.[7] In 1980 Nissan installed twin sparkplugs on the Nissan NAPS-Z engine, with Ford introducing it on the 1989 Ford Ranger and 1991 Ford Mustang four-cylinder models. Several modern Mercedes-Benz engines also feature two spark plugs per cylinder, e.g. the M112 and M113 engines. Some motorcycles, such as the Honda VT500 and the Honda NT400 Bros, also employ dual ignition.[8] The Ducati Multistrada has been modified for 2012 to have "twin-plug cylinder heads for smoother, more efficient combustion", the change contributing to a 5% increase in torque and a 10% improvement in fuel consumption.[9] The 2012 Bajaj Pulsar 200 NS has three spark plugs per cylinder.[10]"
    Dual ignition - Wikipedia, the free encyclopedia
    I knew about the Ranger's 4 cylinder engines having two spark plugs for more efficient burn, but not that that it could benefit an engine that was a liter smaller like in the Civic.
  6. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Off topic, but it is fun to look at those engines and speculate about possible conversion to small aircraft engines. I would feel better flying a home built with dual ignition than single ignition.
  7. Trollbait
    12,461
    It would probably be easy to come by one of the 2.3L 4cylinders from the Ranger. It was produced for at least 11 years, and with the newest being over tens old; a used one should be reasonably priced. I don't know if the newer 2.5L that came out in 2001 or 02 still used the dual plugs though.
    Robert Holt likes this.
  8. Trollbait
    12,461
    Just occurred to me that these dual spark plug automotive engines may not be truly dual ignition. The rest of the ignition system may not be doubled, since such redundancy isn't a safety concern for land bound cars.
  9. Troy Heagy
    Troy Heagy Member
    1,218
    The Civic 1.3 and Insight 1.3 have two spark plugs per cylinder, but one ignition system. Another technique used by manufacturers is to fire the same spark plug 3-4 times per compression cycle. And in the Accord VCM engine, the spark plug fires even when three of the pistons are idle (no fuel injected).
