Just got new tires...now car feels "floaty"'on road.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2007Gen2, Aug 24, 2014.
  1. 2007Gen2
    2007Gen2 Junior Member
    California, California
    I just picked up 4 new tires--Bridgestone Ecopia from Costco.....seemed like a decent deal $400 out the door total. Now the car feels very floaty....as in side to side up and down bouncy.....more so side to side. I know the shocks and struts need replacing...but with the older tires and same suspension I didn't have this issue? What could have caused this? Are the new tires just accentuating the worn suspension components?
    I read the DIY on strut shock replacement.....so I'll probably do that....are there other suspension components that usually need replacing on these cars? Tie rods, control arms??
    Thanks
    #1 2007Gen2, Aug 24, 2014
  2. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Check your tire pressures. Costco probably only inflated them to the door jamb sticker pressures.
  3. 2007Gen2
    What should they be at.....max pressure listed on sidewall of tire?
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,060
    544
    Tucson, AZ
    2021 Prius
    There is usually some "burn in" time for all new tires. The distance varies depending on brand and conditions, and you can likely count on them being settled in by the time of your first rotation. How did the old tires look? Were they evenly worn? I suppose it is possible for new tires to accentuate worn suspension parts. Oil leaking out of your struts means they are toast. An alignment check would reveal what might be worn elsewhere. How many miles on the clock?
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Tires are safe up to the max cold pressure stamped on sidewall. Probably 44 psi, but check sidewall for sure. Not familiar with Ecopia. Most believe that fronts should be 2 psi higher than rears on Prius for handling.
  7. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    most people use 40 front/38 rear
  8. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The EP422s are known for this. Really lousy tire according to the Tire Rack testing and user reviews
  9. fuzzy1
    10,549
    'What should they be' is a matter of personal choice. It is mostly a tradeoff between comfort and handling and tread life and mpg. Many of us take the door label numbers as minimum, sidewall numbers as maximum. The door label number gives better comfort, the sidewall number gives crisper handling, slightly better mpg, and often better tread life, at the cost of a harsher ride and possible earlier suspension wear. You pick your own poison, selecting whatever number in that range works best for you.
    There are also traction and traction-safety issues, but these often devolve into near-religious discussions lacking consensus.
  10. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    If you always use the same tire size indicated on the door label, the auto maker has determined that "X" PSI is the ideal pressure for:
    *Ride,
    *Load Capacity,
    *Traction/Wear,
    *Fuel Economy/Rolling Resistance.
    Source Link
    As Kenoarto pointed out, there are probably a lot who do 40 PSI front, 38 PSI rear. Whatever number you decide, keep the rears 2 PSI lower.
    Art's Automotive recommends 38PSI (assumed front and 36PSI rear). LINK
    This link goes into a good explanation about over inflation. LINK
    A Prius Chat thread on PSI; good read. LINK
  11. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Maybe the worn out suspension is the actual problem here? The OP knew it was past it and then if had been allowed to hang low on the ramp whilst new tyres were fitted it could exacerbate the problems.
    Get your suspension fixed. Usually it's the cheaper parts that fail first so it should be that much of an expense. But it's a safety issue - sort it :)
    dorunron likes this.
  12. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    It likely is the tread pattern. Do they have center grooves that go all the way around the tire ??
    I had a set of Michelin Hydro-edge tires on a Caddy that I just absolutely HATED for that same reason.
  13. Vivian
    Vivian Junior Member
    I got the same ones to replace my worn out Michelin's ( have had tire issues). I have the same issue. At first I thought something was wrong with my car, it was raining and slightly windy. We all know the wind push-pull with the Prius but this was crazy I was all over the road. For several weeks I hated driving on them because we had lots of wind at that time but I have gotten used to them, Would I buy them again? NO. I loved my Michelin Defenders but I worn them out in less than 23000. Same with Nokians WGR3's. Not sure what will be next. I have a 2004 with 151,000.
  14. Patrick Wong
    18,210
    6,511
    Well - if you look at the Tire Rack user reviews and filter on Toyota as a brand, the comments from Prius owners are generally pretty good. I personally have no issue with the Ecopia EP422 and plan to buy another set for the 2004 in the next couple of weeks from Costco here in Tucson.
    I agree that it would help to increase tire inflation; I use 44/42 psi.
    I've also found that tire tread wear has been the best with the EP422 compared to other tire brands/models I've tried with the 2004. I'll probably get ~50K miles with those tires, replacing them when the tread depth becomes 3/32".
  15. Easy Rider 2
    1,584
    258
    Ocala, FL
    Maybe, maybe not.
    If the problem is with the tread pattern (or lack of) in the center of the tire, increased pressure might make it worse.
    Worth a little experimentation though.
  16. Six7390GT
    Six7390GT Junior Member
    Washington State
    I had a set of Ecopias installed on my 2005 Prius at costco. The car was squirmy, and the wind from semi trucks st freeway speed would make the car go offline, even while driving alongside one. In short, I played with tire pressures, but no luck. I went back to Costco and had them replaced with Michelens, problem solved. Costco has a 4 week return period on tires, at least with these tires at that time they did. I thought these weren't just bad tires, but unsafe.
  17. Former Member 68813
    3,524
    983
    US
    Weird. I have the OEM Ecopia EP20 (3rd gen) and they are not bad. I would imagine EP422 were better and not worse?
    Is second gen too heavy for them?
